Thread: My 8G AWD BUILD 329 pictures - NO 56K!!!
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 54
    My 8G AWD BUILD 300+ pictures - NO 56K!!!
    Well after all these years I can finally post pictures of this insanity..
    DONT TRY THIS AT HOME!!!
    Big Thanks to the people that actually made this project possible:
    ---The entire AWD assembly/all custom fabrication was performed by my friend Eugene and Myself
    ---Engine Timing/moral support/general knowledge help goes to Brian (Stewi)
    ---Shop space/Lift/electricity/Welding Equipment for 3 months: Mike, Central Auto, Queens
    ---Cleaning/Painting/Prepping Parts: Angello, Central Auto, Queens
    ---Car is Tuned by E-Spec - Tach Motor Works
    ---Club3G Guys who's research was used in this journey
    Block - Built by Scott’s Auto in Long Island, NY
    ---2.4L block +0.20 over
    ---Wiseco 8.5:1 HD coated Custom pistons
    ---Brand New 2.4L Crank
    ---Eagle H-Beam Rods
    ---King Bearing
    ---AMS Balance Shaft delete kit
    ---ARP Head Studs
    ---ARP Main Bolts
    ---New Water pump/Oil Pump/Oil Pickup
    Cylinder Head - Built by Headmaster, NJ
    ---DOHC Kia
    ---GSC 272/272 Cams
    ---Supertech Oversized Valve
    ---Supertech Guides
    ---BC titanium springs
    ---Cometic MLS head gasket
    ---Ported/polished
    ---SS Manifold Studs
    ---Evo Intake Manifold
    ---PTE 1200CC Injectors
    ---ATP Fuel Rail
    ---EGR Deleted
    ---Nylon manifold gasket
    Fuel System
    ---Aeromotive Compact FPR
    ---Aeromotive 340 Stealth Fuel Pump
    ---Full Blown Twinpump Setup
    --- -8AN Fuel Filter
    --- -8AN SS Fuel Feed
    --- -6AN SS Fuel Return Line
    EVO 8 5speed transmission - Built By DogBox Racing
    ---Stage 1 Build
    ---Chemicaly polished/hardened gears
    ---Mitsu 4.11 Final Drive
    EVO 8 Transfer Case – Built By AWD Motorsports
    ---New ring + Pinion gears
    ---Wavetrac LSD
    Exedy Twind Disk Clutch
    RNR Turbo Manifold
    RNR Custom V-Band O2 Housing
    PTE 6057 Brand New Turbo w/Billet Compressor Wheel + Anti-surge S Cover
    Swaintech White Lightning Thermal Coating
    TIAL Wastegate
    TIAL 50mm BOV
    3" Custom Aluminum Driveshaft - Built By DriveShaft Shop
    KOYO EVO 5 Aluminum Radiator
    Mishimoto EVO 8 Slim Fans w/shrowd
    Borla 3" Muffler
    42 Design Exhaust Tip
    EVO 8 Brembo Brakes
    EVO 8 Leather Front Seats
    EVO 8 Momo Steering Wheel
    EVO 8 Ecu
    Eclipse GSX Donor
    ---Rear Subframe
    ---Fuel Tank
    ---Axles
    ---Auto Diff w/LSD
    ---1/2 Driveshaft
    ---Fuel Filler Neck
    Everything Else
    ---Custom 3" Downpipe
    ---Custom 3" Exhaust
    ---Custom Dump Tube
    ---Custom Fuel Lines
    ---Custom 3" Intercooler Piping
    ---Custom Front Subframe
    ---Custom Radiator Mounts
    ---Custom Rack and Pinnion
    ---Custom Radiator Hoses
    ---Custom Dynomat Floor
    ---Custom Short throw shifter
    ---Custom Interior
    ---Custom Water overflow can
    ---Custom Everything else!!!
    Borrowing Stewi's motor for a mockup
    Smashing a 21MM socket into a galant strut will open it up enough to get on an Evo knuckle
    Rear motor mount difference between Auto and Manual. You cannot install a prothane insert into an Auto Mount.
    This is the difference between Original Fuel Filler neck and a 2G one.
    Done and on the road Again!
    DYNO numbers + Video coming soon!
    Had i known what i know now....
    moved to projects section.
    Didnt know you were such a photog Roman :D
    WOW. very impressive..
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    wow, another awd converted 8g, good job sir! I have a feeling that AWD will eventually be as much of a semi regular thing as doing an LS swap into an rx7
    05-05-2011
    Medford/Long Island, NY
    2,135
    Holy fawk. One helluva build. But I'll tell you what, after seeing it at MOD, it really shows. My hat's off to you, sir.
    -Chris-
    12-13-2010
    Brooklyn, Maryland
    4,643
    Have seen this beast in person, it is not being done justice by these pics. Awesome build Roman!!
    -Greg
    07-19-2007
    Connecticut
    3,994
    nice job man
    02-18-2009
    NEWBURGH, NEW YORK
    486
    I was so impressed to see this car in person . U got an awesome car and great build
    Nothing is nicer then a early 90's mitsu
    02-17-2011
    i live in sunny florida
    1,240
    wow bro awsome job,
    tapa talk was takeing to long to load,i had to tether it to my laptop just to see the pics
    im still lost on why u had cement blocks in the trunk and why it was smoking???
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Wow this is awesome
    4g64T 5spd
    Like chris said i can now really appreciate the work you put in after seeing it at mod then seeing your build! outstanding job
    Simply amazing...
    2001 5 speed 4g64T
    The blocks are there to weigh the car down. Since we took out the rear end the car wanted to flip forward off the lift. The smoke... Micro fire from welding.
    Sent from my SAMSUNG-SGH-I777 using Tapatalk
    02-17-2011
    1,240
    Gotcha and again awsome job, bring that beast to Fla if u can
    HTC EVO 4G
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    11-29-2009
    Chadds Ford, PA
    2,768
    Couple questions
    Why a new floor pan thing
    Is that a crank scraper? Cause I dont remember one there
    When using an evo oil pan, you need a new baffle and oil pickup like that
    11-29-2009
    Chadds Ford, PA
    2,768
    Ah okay, but whats up with the brown floor pan thing? I dont remmebr that in any 3g build or even stewis
    omg amazing build you NY guys are doing it BIG! I hope one day I can be in the same league as you guys!
    Jigz-TGCIL Sosick Motorsports
    Mind blowing 8G, Well done !
    11-13-2007
    -OKC-
    3,970
    Holly crap Roman, beautiful built dude, How do you like the AWD on a G?
