Thread: Maintenance questions on a '06 Mit Galant
Showing results 1 to 6 of 6
    Could some tell me how to the following maintenance? I got it from the regular maintenance schedule. By the way my car is automatic.
    -Replace drive belts (for the generator, water pump, power steering pump)
    -Change manual transaxlle oi
    -Change transfer oil
    -Change rear axle oil, with Limited Slip Diff
    Thanks,
    If you have a 2.4L there is one drive belt and is easy to replace. If you have the 3.8L I have no clue.
    As for the other 3, ignore them. You don't have any of that.
    Oil change 3k
    coolant green 30k
    Trans service spf3 30k
    4cly Timing belt, balance belt, and 1 serp belt 60k
    6cly timing belt, 2 drive belt 60k
    4cly tune up 100k
    6cly tune up 100k? But usually recommend around 60k+
    If my car has only one drive belt which one is it. And how do I replace it?
    Thanks.
    One belt drives everything. The belt tensioner is on the bottom. I just turned the steering wheel all the way to the right and was able to access it through the wheel well without jacking the car up.
