Thread: 4G64, 6GXX, BIG MAPS stock pcm Rom
Showing results 21 to 40 of 85
    Lol. Not yet. Is not added on the 4cly, there still some testing. The v6 is a go. Yours is working.
    Omg... You guys are going to make me work my ass off this year to pay for mods to make this a reality for my car lol.
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    It's working like a charm just wish the clutch didn't fuck up on me I would have had video of a few launches. It's all good thou I'll be launching the new one soon he he he :)
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by deeznutz View Post
    Learn how to drive with a clutch?
    www.blackheartmotors.net
    It's not me b ouch it was the pos spec clutch friggin rivets popped and springs came loose from now on its clutch masters only got it punk!!! Lol
    11-29-2009
    Chadds Ford, PA
    2,768
    And who was driving it when this happeneded?
    Aww now the other punk wants to chime in! Lmao you all ganging up on me? I was is it my fault that spec produces crappy products... I've been doing alot of research about spec ant this is more than a common problem with their clutches, on quite a few occasions it happens around 4k, mine has 4500k go figure.
    11-29-2009
    Chadds Ford, PA
    2,768
    Im just giving ya shit man, when you comeing back to GT? I have heard the same thing, Exedy, and Fidanze I heard are the best way to go.
    I know your just breaking chops whats good for the goose is good fir the hen right lol. Done my research on those as well and are all very good clutches but I'm going to stick with clutch masters from now on I've had more than a dozen clutches from them and never had one issue their just a Lil pricey but well worth the dolla:)
    I poke my head in on GT from time to time..
    02-17-2011
    i live in sunny florida
    1,240
    Ok so ppl with 99-00 pcm/ecu will be ok with this even if they are auto or manual, no tranny codes
    The 01+ will be ok as well if they stay auto, but if they are manual 4cyl or v6, they will have tranny codes to deal with, and Im one of those ppl who hate CEL.
    Is their a solution to this, I kno about the dual ecu but who wants two ecus in a car...
    Or is it the 4cyl only have Tranny codes and the v6 don't
    HTC EVO 4G
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    I guess I'll say it again... this works across the board 99-03, man or auto, 4 or 6 doesn't matter... Isaurio also posted in his 5speed swap thread that he's cel free and he's a 02. I guess you missed that?
    02-17-2011
    1,240
    Guess I did thanx
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    No prob dude
    02-17-2011
    1,240
    What do I need todo to get a Base tune from you with the Mods I have installed, I'm going to a dyno day in a few weeks and would like to help by posting a comparison between stock tune and you base tune,
    I'll have to do some research on how to unlock the ecu and my buddy has the cable to do it with,
    Ps your pm box is full
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    You need an open port 2.0 with reflash connector, laptop and a wide band. You should also have a knock sensor installed if your a 4 banger v6 has one already...
    02-17-2011
    1,240
    Ok well I don't have a wide band and I don't have a knock sensor installed, I have everything else
    Mods I have are V6 TB, CAI, and axle back exhaust,
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Well in order to tune the right way so you know how the engine is responding to the changes your making you must have these things. There's not much room for error and you don't want to kill your engine. If you want to dyno it as is that's fine. The best thing he can do is give you the eclipse mapping but thats as far as I would go anything else is not recommended!
    02-17-2011
    1,240
    That's cool. I'm open to suggestions from the pros, ill have to start looking for a wide band, iirc its not that hard to wire in a knock sensor, right
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    As for a wide band it's Aem ugeo or innovate those would be the top 2 they roughly go for $200. As for a knock sensor I would try getting one from a pull yard with both ends of the harness you'll also need a pin to go into your factory PCM harness. Isaurio will have to open the pin location within the PCM for the knock sensor to work.
  19. #39
    02-17-2011
    1,240
    That is what I was looking into, and as for the knock sensor I can get a new one off rockauto for 30$, as for where it goes on the engine block I have no clue,
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  20. #40
    There's a tap on the back side of the block just right of the oil pressure switch it just screws into the block, wire goes into cabin to PCM one is ground the other is, and I'll have to double check on the year of your car, if your 02-03 it's pin 80 if I'm not mistaken...
