Thread: 4G64, 6GXX, BIG MAPS stock pcm Rom
Page 5 of 5 FirstFirst 12345
Showing results 81 to 85 of 85
  1. #81
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    Buy adjusting the fuel and timing on a stock motor i seen some gains with a base smoothing tune. Both v6 and i4
    Pm me if you interested in a base tune.
    I may in the future. What kinda gains like maybe a couple horses at most?
  2. #82
    06-13-2008
    Bronx, NY
    2,606
    Depends what mods u use. If you put 93 or 91 oct a few hp.
    SOHC Turbo
  3. #83
    Member
    06-18-2012
    RIVERSIDE CA DAT 951 AREA CODE LOL
    183
    I use 87 octane in my galant is that bad?
    GWAP STACKIN MAKE'S IT HAPPEN
  4. #84
    06-13-2008
    Bronx, NY
    2,606
    For the 4cly is not. But when you start adding mod like tb, intake, headers. Your taking more air in to the cylinders, the MAF try its best to notice the extra air and adjust the injectors, but you always need fine tuning.
    Now when you do base tune for hp gain or to make the most out your mods the timing needs to be adjust, increasing timing means more power but also means probability of knock. The lower the oct the more you knock the more damage you cause the engine. The higher the oct the more timing the fuel could handle. I run 93 oct fuel all they long. Any engine love good gas, it last longer, the gas is cleaner, and is great for boost and tuning.
    SOHC Turbo
  5. #85
    11-18-2009
    Buffalo, NY
    1,758
    Hmm...I guess i'll be switching to a higher octane gas with the mods i currently have
    - Chris -
    DRL Delete
