Thread: 04 Galant GTS Radio Error
Showing results 1 to 2 of 2
    I just bought a 2004 Mitsubishi Galant GTS from a local dealer. It has the infinity stereo system installed. I checked the radio to ensure that it worked; however, I did not check the CD Player.
    Everytime I try to eject/load a disc, it says Error 03.
    Does anybody know how to fix this? Or if it can be fixed? Or how to take the radio out to try to fix this? I really need the CD player to work.
    I really appreciate any help you could give. Thanks.
    Unfortunately there is no fix for this, usually this type of error is a sign of a faulty player. Your am/fm will still work but as far as the CD, it wont. Even if you get it to take a CD, odds are its gonna get stuck in there and throw an error again.
