Originally Posted by
SPD_FRK
Clean around the oil pan where it seals to the engine block first, drive it for a day or two and check to see if there is oil coming from that area. It may be just an oil pan seal that is failing on the rear portion. Generally if it is a rear main seal leaking you will have a lot of oil build up on the bottom of the bell housing, and residue build up from the bell housing area around to the rear of the subframe from wind pushing the fluid backwards as you drive the vehicle.
