Thread: Yellow Foglights
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 50
    Yellow Foglights
    Where can i get yellow foglights?
    05-05-2011
    Medford/Long Island, NY
    2,135
    You looking for yellow bulbs, or the yellow overlays for the fog lens?
    -Chris-
    Buy them on ebay or ddmtuning.com
    3000k will be yellow
    04-10-2005
    NYC
    3,695
    you can just get yellow tint film. heat it cut it and done. try ebay
    most auto stores have the spray stuff too
    05-02-2008
    Hacienda Heights, CA
    3,014
    i sprayed mine
    Duplicolor metal cast in yellow..some painters tape and some aluminum foil for masking. Months later still holding up. If you use it..do light coats and build. Too much at one time ruins clarity. If you have a hair dryer..you could spray, then blast it on high for a minute, then another coat and so on. About 3 coats should do
    03-16-2010
    Maplewood, NJ
    1,290
    If you want overlays, go to ebay. You might also want to do yellow bulbs behind the yellow film to make it deep yellow.
    Has anybody used Krylon Stained Glass Color Spray Paint?
    That's probably what I would use if I were to do that, due to the fact its meant to have transparency.
    11-29-2009
    Chadds Ford, PA
    2,768
    you could always do lexues capsules
    just go with some ddm 3k's!! thats what i have
    STAY READY AND YOU WONT HAVE TO GET READY!!
    they look really yellow at night!
    Yellow bulbs = dark halogen colored lighting ($17- 35)
    Yellow tint/ vinyl = piss yellow ($20- 30)
    HID 3k = bright, brilliant yellow lights ($35 - 60 for inexpensive set)
    In the end, you'll probably end up with the HIDs.
    I'll probably go with the Krylon Stained Glass Color Spray Paint and ddm 3k's combo.
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by GALANTICS View Post
    Its gonna be tiger piss yellow
    I'm actually going for lion piss yellow.
    I went with the duplicolor over krylon, for some reason I forget. I think it was a color issue. But besides that the duplicolor is resistant to some solvents and oil I think I read on the can, plus holds up to heat well. So I was sold. I have yellow bulbs too. But I had them prior to spraying the lenses yellow.
    lolol.
    Won't a yellow lens reduce the output?
    RadRICH - TGC Founder BGR's Avatar
    12-09-1999
    FLORIN - Sacramento, CA
    1,996
    I bought these (893 yellow bulbs), less than $10 shipped for 2:
    http://www.ebay.com/itm/Golden-Yello...ht_3118wt_1169
    You can also buy these for around $50 shipped. I bought a set of these a few years back and never installed them.
    http://www.ebay.com/itm/1999-2001-MI...ht_2848wt_1401
