well that all depends on width, tire selection, and how extreme of a roll/pull you do on the fenders, so why don't you tell us the width and tires size you wanna run, and we'll go from there. oh and the camber too, if you want a meaty tire setup I would go with something in the range of 8-9.5in wide with an offset between 25-40 depending on which width you go with, and again, depends on the tire size and camber, as for the hellaflush fanboi setup you could easily run a 225 or a 215 on a 9.5-10 wide wheel and slam the car. What exactly is your goal here? Also, without coils, you will have clearance issues on the struts of your car if you run something that's wide with a too high of an offset.
