Thread: I am NOT going to spill anything in this thread
Page 4 of 11 FirstFirst 12345678 ... LastLast
Showing results 61 to 80 of 214
  1. #61
    11-29-2009
    Chadds Ford, PA
    2,768
    OP do u mind taking few close up pics showing the harness. I'm gonna attempt to make my own.
    Yeah I can give me a bit.
  2. #62
    11-29-2009
    Chadds Ford, PA
    2,768
    I have the pictures but have been crazy lazy in uploading and making a thread. Also got some parts in
  3. #63
    08-08-2004
    Las Vegas
    2,099
    yah there is no need for a conversion harness unless you ever want to go back to an auto ecu... take the 3g eclipe connectors off of a wrecked car, then one by one remove the pin from your auto harness connector and put it in the eclipse connector.
  4. #64
    Isn't there a couple wires different in the 02 03 range?
  5. #65
    08-08-2004
    Las Vegas
    2,099
    for the transmission yes im not sure about for engine functions.
  6. #66
    11-29-2009
    Chadds Ford, PA
    2,768
    Here are the parts that came in.
    Fuel rail-evo paid $38
    Clutch, I have heard good things about the 6 puck with the upgraded pressure plate. I will see how it is. paid $187
    I will get a stock TOB
  7. #67
    11-29-2009
    Chadds Ford, PA
    2,768
    Here is the photo album I dont feel like copying and pasting all these
    http://s1020.photobucket.com/albums/...ion%20harness/
  8. #68
    Thanks for posting the album.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  9. #69
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Hey bro can you tell us more info on that clutch setup you got? Did you buy it from aimcoclutch on ebay? Whats like the general consensus about it?
    Since you said you read good things about it with the HD PP, what about the other PP(the red one) complete garbage?
    4g64T 5spd
  10. #70
    11-29-2009
    Chadds Ford, PA
    2,768
    I got the stage 4 6 puck with the HD PP, Yes I did buy it from aimclutch. Welp really couldn't say just looking at it in the box. The dsm guys rave about this cltuch and many have had great dealings with it.
    From what read though its not the disc that goes its the pressure plate as the stage 1-3 uses a oem Pressure plate and at any bigger power levels over stock they were bending fingers. If you go onto DSM tuners there are tons of reviews and somewhere there is the information I said. I just cant find it.
  11. #71
    Is it a 3g clutch or a 2g??
    '95 Kawasaki ZX9R
  12. #72
    11-29-2009
    Chadds Ford, PA
    2,768
    It's a 2g but they are the same for both.
  13. #73
    That's what I though and I looked on the ASA and it showed 2 different part numbers.
    Are u using it with the 2g flywheel or the 3g flywheel??
    '95 Kawasaki ZX9R
  14. #74
    11-29-2009
    Chadds Ford, PA
    2,768
    My guess is that the stock 2g is probably more heavy duty and resistant to power since it makes more power stock. I think most aftermarket 2g gs-t and 3g gs/rs clutches are the same.
    I went with the 2g as it was cheaper than the 3g counterpart. Also I believe it is slightly lighter. I don't mind spacing out the starter.
  15. #75
    I wonder of we could use the 2g clutch with the 3g flywheel.
    '95 Kawasaki ZX9R
  16. #76
    11-29-2009
    Chadds Ford, PA
    2,768
    Should be able to
  17. #77
    05-03-2009
    1,465
    When I was at my swap I think it was qnzmostwanted that told me that 2g and 3g clutches are the same, the only thing that matters and would require spacing the starter and longer flywheel bolts is if you go with the 2g stock or any 2g/3g aftermarket flywheel.
    4g64T 5spd
  18. #78
    Any 3g flywheel stock or aftermarket don't need the starter to be spaced. Only the 2g does. I wanna compare the 2g and 3g clutches and make sure before I buy one.
    '95 Kawasaki ZX9R
  19. #79
    11-29-2009
    Chadds Ford, PA
    2,768
    I can let you know when I pull the motor.
  20. #80
    U have the 3g set up on your car now and u swapping it with the 2g set up??
    '95 Kawasaki ZX9R
