Thread: Finald8ta other projects
Showing results 1 to 18 of 18
    02-17-2011
    i live in sunny florida
    1,240
    Ok so I'm helping a friend out
    Car- 2001 eclipse
    Car was auto then went turbo with dual ecu, shortly after he went 5speed,
    car has been having a lot of issues since the swap, after looking over the dual ecu set up and seeing what was not working in EVO scan we narrowed it down to the wiring harness, I notice a lot of broken wires and a lot of sensors not working properly in evoscan, he then tells me he has a replacement engine harness from an 03 mt, I start pokin around at engine diagrams and what not only difference was fuel pump relays, I was wrong
    I wasted week on trying to figure it all out and come to find out
    After looking at wire diagrams between the 00-02 and 03-05 eclipse both engine harness are completely different same with the body harness,
    You can't put a 03 engine harness in a 01 with out rewiring a lot,
    So initially I need a 00/02 mt engine harness to make this all work
    It's hard to explain but the pin outs to the ecu are the same it has something to do with the body harness and the way its wired up differently between the yrs,
    So the new plan is to head to the Junkyard pull an auto wiring harness from a eclipse(00/02) or galant (99/01) and go this rout and wire in the EVO ecu,
    Anyone looking to do a true swap to a 5speed I might have a engine harness from an 03 MT eclipse for sale. Once I pull it back out, EVO ecu will plug right in
    I haven't gone over the galants diagrams yet but if they are the same as the eclipse I'm 100% sure it will all be PnP
    Note- I'm not sure what yrs have the new style fuse box under the hood but a tip would be is you should have 2 fuel pump relays in the fuse box in the cabbin instead if it being under the hood, this is from looking at the eclipse diagrams
    I'm assuming it might be yrs 02/04
    Correct me if I'm wrong,
    I'll post pics when I can
    Sent from my PC36100 using Tapatalk
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    02-17-2011
    1,240
    Never made it to the yard but I did snag a mt harness from an 01 eclipse and got her to fire up,
    I had to trick the mfi to get it running but when I put the mt ecu in the mfi relay are working the way it should... Gots to dig in further
    Going to compare pin out for 04 EVO ecu and 01 eclipse ecu.
    I kno for a fact that the EVO will work perfectly in an 03 eclipse....
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    I could use some some.. when I plug in the 01 mt ecu the mfi relay works the way it should and im able to get in with ecuflash and evoscan, when I plug in the EVO ecu I get no power to the ecu, I checked pin out to both ecu and all is the same..
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    For anyone who cares, she LIVES, got some issues to work out but other then that I'm done for tonight
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    11-18-2009
    Buffalo, NY
    1,758
    Pics?? We like pictures :)
    - Chris -
    DRL Delete
    02-17-2011
    1,240
    I'll see what I can do tomarrow I have a bunch to post up but no internet to load them to PB, ill take a few with my phone tomarrow. And maybe a video.
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    Ok here some pics automatic converted to a full five speed and harness from an 01 eclipse I pulled for 20$
    The 03 harness won't work due to different specs like diagrams, fusebox,
    Currently running on the mt ecu flashed over from his EVO ecu Rom.
    The EVO ecu for some reason will not work because its not triggering the mfi relay for the ecu to get power, but the mt ecu works,
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    ^in the evo ecu there are 2 to 3 immob issues you have to disable, I thought there was only two, in one table you put FFFF in for the hex code to disable it, and then in ecu pheripharies? (sp) you need to put a "0" to disable it on ecu flash, as far as the third one is, idk your best bet is isaurio. but thats your problem, the immob
    02-17-2011
    1,240
    I'm currently talking to isaurio threw email, the immob is diable from what I can tell
    I'm still looking into it,
    With the EVO ecu I'm not getting any power to the ecu unless I trick the mfi relay, with the mt ecu hooked up it works just fine but it won't start due to the immob, so I copy his Rom to the mt ecu.
    And I was able to fire it up
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    Ok nothing really to report car runs like SHIT, found out there's no knock sensor installed, gona get that sometime this week, and the egr silonoid is broken, good thing I have a spare from my intake swap I did, still need to hook up the manual boost controller, and run a new fuel return line, plug up a hole on the aem intake that's being used and put the air box back in,
    And figure out a good base tune to keep it running,
    If this is the shit I'm gona have to deal with when I turbo my G it's not going to he a fucking hack job,
    Hopefully isuario i4 patch for the auto ecu will work out cuz that's the rout I'm going.
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    11-18-2009
    Buffalo, NY
    1,758
    I thought all eclipse's had a knock sensor installed?
    - Chris -
    DRL Delete
    02-17-2011
    1,240
    The motor been replaced, who ever did it didn't swap over the knock and broke the egr soloniod
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    06-13-2008
    Bronx, NY
    2,606
    Quote Originally Posted by Rach3T8G View Post
    Yes they do. Galant dont. But it could be done. Port 90 in our pcm and needs to enable the sensor via rom. Very clean and works oem. I believe im the only one that have that mod with the stock pcm. Is a most big help when you tuning boost map or big maps.
    SOHC Turbo
    02-17-2011
    1,240
    And she idles like a champ, pics and video I will get soon
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    06-13-2008
    Bronx, NY
    2,606
    With what rom?
    SOHC Turbo
    02-17-2011
    1,240
    With what rom?
    Just the eclipse rim for now
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    02-17-2011
    1,240
    update, finally got the car to run, didnt take it for a drive due to knock sensor not installed yet, im currently running off the eclipse MT ecu with immob delete,
    everything was running great till it reached 185* and i lost idle, no biggy, i was able to get it running, now i have some other issues to work out, like i think the stock fpr is(there is an aftermarket install as well) holding me back, because when i start it it starts to run lean,
    im working with the owner and he plans to get an evo fpr and rail for me,
    on to the evo ecu, ive gone threw eclipse and evo diagrams and stll cant figure out why the ecu wont power up, im to the point where im gona flash over the evo rom to the eclipse MT ecu and call it a day,
    c3g is total waste of time no clear answers and some threads just rant on about others not knowing how to search, when theres no clear answer, at all to the thread, and on top of that half the posts have been removed,
    any info will help, to help me figure most of this out, i wouldnt mind an open disscusion about this ether
    06-13-2008
    Bronx, NY
    2,606
    Im glad somethings are working.
    SOHC Turbo
