Thread: header question
Showing results 1 to 4 of 4
    FirstWHIP9gen
    Icon4 header question
    Ok I'm lookin up headers for my 05 galant DE and I kno my engine size is a 2.4L its a 4G69 but on the website it says "Stainless Steel Header Eclipse Mivec Fits ALL 2004-06 Mitsubishi Lancer Ralliart edition with the 4g69 2.4L mivec engine Do not fit Eclipse Mivec" will it fit my car ?? Cause I kno the eclipse has the same motor ...
    will v6 eclipse headers work for my v6 galant?
    4g eclipse header will work. RRE shortee are a direct replacement. Obx requires 2 more 02 sensor bung to be welded on and get a flange welded on to the match the mid pipe.
    Same goes with v6
    NEWBIE
    09-16-2009
    Hollywood, Florida
    36
    If your looking at OBX headers, only the one made for the eclipse will fit. The design is similar but different between the OBX Longtubes for the eclipse and lancer. It also has to do with the down-pipe routing.
