Thread: Engine mounts
Page 3 of 3 FirstFirst 123
Showing results 41 to 45 of 45
  1. #41
    im in the middle if building a turbo motor and i well be going awd.. but what i want to know is if i can use the evo motor mounts?
  2. #42
    11-29-2009
    Chadds Ford, PA
    2,768
    I think they use a dog mount style for the rear. Sides might be the same.
  3. #43
    thanks, i will look into that..
  4. #44
    You use 8g front and side and manual eclipse transfer mount. And in the awd you use the evo8 rear transmission mount(also depends on the subframe decisions you make)
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  5. #45
    the window welded mount in my 8g 5 speed swap its been holding for going on 6 months now and i have no issues from it 2 do all 4 u might need 2 tubes of it but its cheaper than the inserts
