Thread: new guy with galant issues, go figure.
Showing results 1 to 15 of 15
    Banned
    02-04-2012
    put 5k into a 2k car idiots
    42
    hey guys, im eric.. i have a 1999 es that hasnt let me down since ive owned it for just over a year...
    i was planning on selling it, but id never get what i paid for it.. or what i put into it, so ill just hold onto it and go ahead and make some repairs on it that i wasnt planning to make originally..
    1) upper socket for rack&pinnion (play)
    2) horn/cruise control not working (srs) light
    3) no hot air, vent selection INOP , fresh air/ac buttons INOP
    4) valvetrain (ticks)
    anyone ever transplant sunroof onto regular hardtop?
    4,455
    Welcome to TGC|
    Jason - - cofounder of TGCNY
    2001 Galant ES
    12-13-2010
    Brooklyn, Maryland
    4,643
    Welcome to TGC! Check fuses for issues with the whole HVAC not working, even when my heat went out, the fan would work and all that. If only max was working that'd be the resistor. For the horn/srs light, fuses and/or clockspring or other wiring, I've never had to work on any of that. Hope this helps some.
    -Greg
    Welcome to TGC. for the horn issue its more than likely your clock spring
    Welcome to TGC!!
    Banned
    02-04-2012
    42
    Welcome to TGC!!
    ty,, those eclipse wheels fit good? how much do a used set of those usually go for... i cant stand running hub-caps.. i was thinking about throwing some old BMW wheels on it.. seing how im a bmw guy
    Any Eclipse wheel fit no problem, in fact those are the OEM wheels from my 3G. You can find them on craigslist between $200-$400 depending on wheel/tire condition.
    Banned
    02-04-2012
    42
    thanx! the play and road noise is getting bad... very bad gas milage and extreme tire wear.. i gotta get on this asap..
    Quote Originally Posted by 1999ES View Post
    ... i was thinking about throwing some old BMW wheels on it.. seing how im a bmw guy
    BMW wheels won't fit unless they are 5x114.3 (USDM 8G bolt pattern), most BMW's are 5x120 right?
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    I never worked on my rack and inion but when I did have play it was from my tie rods, and my ball joints, check those out. As for the tick I had it. But do this first before you think u need new lifters get all gaskets for you valve cover. Cover gasket, pcv gasket, all spark plug cylinder gaskets, and new oild cap gasket I changed all that and one lifter on my exhuast side (but don't worry about the lifter yet) and my tick went away. So if u have black debris around your valve cover its prob letting air in which is also a cause of lifter tick.
    You let those known problems go on for 6 months? Yikes. Glad it didn't break down on you.
    Yes, all BMW are 5x120.
    1) net with a new rack and pinion, or at least one that is remanufactured.
    2) check the fuses first.
    3) could also, besides fuses, be the heater control valve actuator, very common failing on these cars.
    4) make sure you have adequate oil in the car first...lol. then you can suspect things like lifters. It could even be the type of oil you are using.
    TGC Regular djhah's Avatar
    03-15-2010
    nashville, tn
    505
    Mine ticked for a short while after I did my head gasket but agent away after my first oil change ( plus I had to tighten down valve cover some more one bolt worked its way loose). Welcome to the club you will soon be hooked once you start reading the forums :)
    Welcome to TGC :)
