Thread: back up cam
Showing results 1 to 10 of 10
    back up cam
    hey has anyone install a backup cam on their 8g i would like to no what wires u use for power and ground. i have one on mine using it on a pioneer avh 5200 but it does not allways was come on when i put the car in reverse. the way i have it hook up now is by using the power and ground of the lights the come on when u put the car in reverse
    02-17-2011
    i live in sunny florida
    1,240
    I have mine wire to my amp for power, and my deck set to where it will stay on till I push a button on the deck to turn it off.
    I have a pioneer avh-p4900dvd
    When I want to turn off the rear camera I push v.adj
    Hope this helps
    Sent from my PC36100 using Tapatalk
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    Quote Originally Posted by finald8ta View Post
    Hope this helps
    This is confusing, I get what you do to get it to work but to the lay person too much involved.
    Smash: you have it wired correctly, that is how it should be wired. Check all your connections for something loose or pinched.
    02-17-2011
    1,240
    Are decks use the same settings
    I used to remote wire witch is a 12v switched, I had the same issues wired to my backup lights
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    if your useing the remote wire you need to run a relay or it well put stress on your headunit and it well prematurely fail
    -Dirty South-
    02-17-2011
    1,240
    It's been running fine with the way I have it wired up, right now its not hooked up and I plan to replace the 10yr old amp and sub with somthing newer, and the deck
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    It's always worked fine because the camera is always on. And yes it will stress the decks remote signal. If you are happy with this method use the red wire that triggers the radio on for a safer connection.
    02-17-2011
    1,240
    I'm bona end up removing it any way I don't even use the Danm thing lol
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    With these cars who needs a back-up cam. I have one in my 04 Tahoe, it has 5% over factory tint so at night I can't see anything. the HID's in the back help out alot in seeing with my non IR Cam.
    02-17-2011
    1,240
    I wanted to use the feature on the deck so I picked up an ebay rear cam for 15$ works great just I don't look at the screen to back up, I was thinking of putting a dvr system or carputer to record and lost intrist in it before I started, so the new plan is the install a newer amp remove the backup camera replace the deck and sub, all that equipment is like 10yr when I had my first car, only thing new stereo wise is new front speaker lol and that was done last yr.
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
