Thread: HID fogs installation...help
Showing results 1 to 20 of 33
    02-08-2012
    Hackensack NJ
    1,146
    How do you put HIDs in the fogs? I have 3000k fogs I tried to do it and nothing happened. They're brand new lights and ballasts. Do I need a relay to install them? I have one just incase I need it. I'm just waiting for a nice day and some time to do it.
    Same way you would do it on the headlights. And yea use the relay. Make sure your (+) & (-) are correct.
    02-08-2012
    Hackensack NJ
    1,146
    Oh ok so I DO need the relay...when I tried before I didn't have a relay so that's why I bought one. So I should be good with the relay?
    Experienced TGC Member Bloody Arro's Avatar
    04-14-2009
    Highlands, Tx
    1,066
    Like was said before, check your +/- and make sure they are right. The lights should turn on without a relay if it is wired up correctly.
    And fwd grocery fetters are fun, you wouldn't be on this forum if you didn't agree
    Quote Originally Posted by 8thLS6 View Post
    Tuning to me is like magic... I don't understand it but it makes things happen lol
    02-08-2012
    Hackensack NJ
    1,146
    Oh really? I checked the + and - and flipped them and still nothing. That's why I got the relay
    03-16-2010
    Maplewood, NJ
    1,290
    What I think Bloody Arro is trying to say is reverse your polarity. The cord that plugs into your ballast, if it doesn't ignite when plugged in, flip that cord around and see if it works
    02-08-2012
    Hackensack NJ
    1,146
    Right I understand that and did that and nothing happened. Again that's why I got the relay and I will try it with that soon
    03-16-2010
    Maplewood, NJ
    1,290
    Hmmm... that's weird. Keep trying. The bulbs will ignite without the relay if hooked up properly. Keep messing around with it. Im sure you will figure it out eventually. If not by the weekend, let's meet up so I can help.
    02-08-2012
    Hackensack NJ
    1,146
    Ok thanks I have some friends who're really good at these so they'll prob help but if not we can def meet up
    I think you blew a fuse. Put a 20a or 30a in its place. Stock 880's are 27.5w and HID is at least 35w. This is why its best to use a relay! (For those who plug n play) Stock fuses and wiring are just rated too weak and wires too thin, they will fray and can cause damage to your cars wiring.
    For longer ballast and bulb life use relays with heavy gauge wiring with all HID installs especially those higher than 35w, like DDM 55w.
    Ever wonder why there's monkeys who roll with one HID out? No relay+bad ground from stock wiring=shorter lifespan and/or HID flicker. I have 2sets of McCulloch HID kits that are 6yrs old that still work like a charm, and I think using relays with proper awg wire and good grounds has a bit to do with it.
    Sorry if im just rambling on, but I explain this over and over, newb after newb, forum after forum.
    02-08-2012
    Hackensack NJ
    1,146
    Ok thanks for rambling it helps but I didn't blow a fuse because the stock (or in his case luminics yellow bulb) still worked after I put it back in. I might have raised the amps but I would have to l
    02-08-2012
    Hackensack NJ
    1,146
    Look
    make sure ur high beams are off (low beams must be on)... the fogs will not work at the same time as the high beams because of the way the lights are wired from factory. the fogs also will not work unless you have your low beams on.
    02-08-2012
    Hackensack NJ
    1,146
    Yes I understand and knew that maybe its the ballasts since I tested the bulbs in my existing hid ballasts for heads and they worked but did anyone else need a relay for fogs?
    10-05-2008
    Grand Rapids Michigan
    1,141
    The Bulb the G comes with is a 893, same base as 880, just at rated 37.5W not 27.5W.
    02-08-2012
    Hackensack NJ
    1,146
    Ok I'll check it
    Sometimes the pins on the HID harness get bent going in so check to make sure they have good contact.
    08-08-2004
    Las Vegas
    2,099
    so if your fog bulbs work with the low beam ballast, and your low beam bulbs work with the low beam ballast. do your low beam bulbs work with the fog ballast? if you test that you can see if the new ballast is broken.
    02-08-2012
    Hackensack NJ
    1,146
    Hmmm good idea
    Out of curiosity JD, what brand HIDS you have?
Tags for this Thread
