Not difficult at all. Make sure you buy a can of penetrating spary like pb blaster to loosen up the O2.
Hey guys. I had a service engine light for a while and it happens when I press the gas with medium to high pressure from a stop since the car like slips/hesitates before it goes. I went to Advanced Auto Parts and will go to other places to check the error code. It was PO138 which is a problem with the oxygen sensor. If that's the case, how expensive/difficult is it to replace it and is it a job I can do or with a couple friends?
Depends on where you buy them and the type you buy. If you're strapped for cash and know how to solder, then you can go to autozone and get a universal one (ensure that it fits) for $60 or so. If you're not in a hurry, you can buy both of them for $70 total on ebay.
Scott
I didn't but I looked up the part to this car and these came up. I opened them and they have a few adapters which should work and if not it's just simple splicing
