Thread: Carbon Fiber JDM eye lids
Showing results 1 to 6 of 6
    02-08-2012
    Hackensack NJ
    1,146
    Hey there I have an 03 Galant ES and was wondering if these JDM eye lids would fit even tho i don't have JDM head lights
    http://www.aliexpress.com/store/1046...tock-Free.html
    The JDM Galant headlights are wider than the USDM version, so no.
    according to the description will fit just needs to be trimmed
    It fits the original Japan spec. Galant. For US spec galant, since the light is shorter, need to trim the eyelid a bit to make it fit.
    these are made for the JDM 2 piece heads that have the "protruding" corner lights. look at the eyelids where they go over the corner lights, there is a "bump" where there is no bump on JDM 1-piece, JDM 2-piece w/ flush corners or USDM headlights. here are the headlights that they were made to fit (see the bump on the headlights?):
    02-08-2012
    Hackensack NJ
    1,146
    Ah I now know thoroughly I the size difference but never noticed the bump
    keep looking around. i know i have a set floating somewhere in the garage that were made for the jdm headlights but also fit the usdm because of the design.
