Thread: JDyal's Black 03 ES 2.4 Cyl Build
Page 20 of 22 FirstFirst ... 1016171819202122 LastLast
Showing results 381 to 400 of 433
  1. #381
    There's no continuity with the new wheels. The car flowed with the old wheels, now it doesn't.
    IMO for the time being I'm thinking ita only because of the ride height, and missing cladding. I know 3m supposedly has a an adhesion promoter you can get too
    But yeah a clean surface is critical. Also which tape did you get, cause I know they have a molding tape you can get at autozone. It was strong enough to attach some fog lights I got for my old s14 once, in an upright position on the bumper. It held even til the day I decided to remove them (oem later ftw)
  2. #382
    02-08-2012
    Hackensack NJ
    1,146
    Oh ok what was the name of the tape?
  3. #383
    Jhun35
    car looks really good man. Keep it up!
  4. #384
  5. #385
    02-08-2012
    Hackensack NJ
    1,146
    Ok I've seen that at advanced autoparts and it does work well so i'll get it
  6. #386
    07-12-2007
    SoCal
    4,632
    Those wheels make the car look soooo much better. Finish your projects & drop it, and then you will have a very clean looking G.
    JDM Zenki Conversion
  7. #387
    02-08-2012
    Hackensack NJ
    1,146
    Yeah I plan too. I did the cladding that needs to be adjusted and just need to get the front and rear fenders. I'm also working on meshing out the stock grill and retrofitting the fogs. I have fender flares that need to be painted and idk how to put them on properly and I also have an obx header and a v6 tb that needs to go in but I'm waiting to get an Outlander IM. I just got a little license plate relocate kit and still contemplating on where to put it and white gauges that may want to put on since I like my blue lights already in there. In the future I'll drop it, I don't have the finances now tho.
  8. #388
    02-08-2012
    Hackensack NJ
    1,146
    Forgot to post this up. I did the license plate relocate at the corona bbq
    I just need to sand where it was and fill it up, sand again, and repaint it. Since I used screws just to screw it in to the bumper, I'm wondering if I can get a piece of sheet metal and cut it the same size as the plate to give it backing and make holes in the plate and sheet metal in the center on both sides so i can screw it to the bumper like how lancers have it. Don't get me wrong i like this but it looks a little awkward and I ideally would like it on the side. The locator wouldn't fit there evenly and since it only mounts on from the top, it'd block the headlight or foglight. My theory is if the plate is screwed in the middle on the bumper, it may clear both
  9. #389
    Looks fine where it is leave it alone!!!!
  10. #390
    05-05-2011
    Medford/Long Island, NY
    2,135
    I'm with Dion, leave it where it is. Looks fine there.
    -Chris-
  11. #391
    02-08-2012
    Hackensack NJ
    1,146
    Ok I'll leave it then and another question, I have the angel eyes with my retrofit and they don't work even when hooked up to power, so do I need some kind of relay? That's the only thing I can think of.
  12. #392
    Did they come with transformers? What brand? And where did u get them from? yea the plate looks good where it is that's where I put mine but I didn't use no fancy bracket like you did, I saw u tinkering with that thing at corona
  13. #393
    Should've just left it in the OEM location.
  14. #394
    This.
    <----This guys opinion: looks out of place, like someone broke your plate mount and it just got thrown off to the side as a result.
    Whatever tickles your fancy d00d. Heads look pretty good though
  15. #395
    Quote Originally Posted by JDyal View Post
    It may work for other cars, but some how it never looked right on the 8g bumpers.
  16. #396
    02-08-2012
    Hackensack NJ
    1,146
    Quote Originally Posted by deeznutz View Post
    They came with a power supply that you had to plug them into from TRS but when I tested them against the signal wires they didn't work so that's why I think it needs some kind of relay
    This.
    Yeah I kinda see that and I'm getting mixed reviews as well. My buddy recommended it to me since it looks good on his corolla but that bumper is big as hell where ours isn't, but I may experiment with that. Thanks about the heads, wasn't as hard as I thought and they're beautiful
    Quote Originally Posted by G-spot View Post
    Yeah I see what you mean hence why I wanted to test my hypothesis by putting it on the side like where the lancers have it.
  17. #397
    If they r LED, try reversing the polarity. Sometimes LED's have a positive and negative side and will only work when wired that way, unlike regular bulbs that can be hooked up either way.
  18. #398
    Too add to what relax said, check the polarity and make sure you arent connecting to the turn signals.
    Sent from my Rooted Droid X using hacked Tapatalk 2
  19. #399
    02-08-2012
    Hackensack NJ
    1,146
    I think I did all of the above but I'll try it again...
  20. #400
    02-08-2012
    Hackensack NJ
    1,146
    Hey I haven't posted in a while but I took out my blue bulbs in the cladding and put these white ones in
    I forgot the blue bulb for the mileage part of the odometer but I think it looks pretty sweet. I have the white bulb so i might swap it so there's continuity.
    I also have the cladding on but for some reason the rear driver door one is damage and everytime the door is opened, the split part of the cladding slides in between the driver door and driver cladding. How can I fix that?
Tags for this Thread
