Thread: lower timing belt cover
Showing results 1 to 14 of 14
    so guess as you know im trying to replace the crankshaft position sensor on a 2000 2.4l mitsu galant... and currently in process of it... so far i removed alt belt and powersteering belt... to access the lower timing belt cover do i need to remove this "pulley"?
    and if so how do i
    by removing the 4 small bolts on the gear or do i fit a 1/2 torque wrench in the middle and go counter clockwise...
    as always thanks for your help in advance...
    wise up or stand down
    yes. middle.
    All bolts need removing. If you can use an impact.
    removing the middle bolt isn't necessary since it only holds the crank pulley in place. Removing those 4 bolts and use a rubber hammer will release that pulley from the center piece.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    ^^ Correct. IIRC the bolt goes right through the pulley. Kinda disappointing to see the smaller bolts is all that holds the main pulley.
    oops guess i remembered wrong my bad. its been a while.
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    only the 4 bolts then its hammer time :D did this a couple of months ago
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
    Thanks guys...always appreciate the help and fast response...
    I only remember that cuz the oil pump cover leaks and I took it off and replaced the gasket about 3 times and I did the timing belt on my other g and my cousin's g too.
    '95 Kawasaki ZX9R
    is v6 different or somthing? cause i seem to remember i had to take off the middle one.
    Quote Originally Posted by dknight3 View Post
    I never messes with one but I know the first time I took it off the pulley was stuck on that center round piece and nothing I did made it come loose.
    '95 Kawasaki ZX9R
    04-14-2011
    Iceland
    533
    yeah that think is most likely well stuck i thought i had to take the middle bolt out too but then when i was trying to get it lose the #wheel or what ever # fell off
    Old ones
    THanks for all the help guys.. i successfully changed all my belts: timing, balance shaft belt,a/c powersteering alt belts, tensioners, water pump and CRANKSHAFT sensor.... with your guys help and the Haynes manual....by the way haynes manual is not the greatest help for a first timer...especially trying to balance the oil sprocket thing.. sucked ass... the Plug took me hours to find... its the bolt right underneith the starter and behind the headers down pipe.....IF any one have question feel free to hit me up..
    08-08-2004
    Las Vegas
    2,099
    glad you got it worked out. its satisfying doing your own work huh. your right about the manual lol
