View Poll Results: Which amp should I GEt
Voters
1. You may not vote on this poll
  • MTX 4250D
    0 0%
  • MTX TA2301 (Thunder 2301)
    1 100.00%
Thread: Need help selecting a new amp
Showing results 1 to 4 of 4
    You are here entirely tooo much!! Serstylz2's Avatar
    09-10-2003
    Charlotte, NC
    4,463
    Looking at two MTX Amps, either the 4250D used for a pretty cheap price (<$70) or a brand new TNA 2301 for 105 shipped. Both class D amps, birth sheet on the 4250d says it puts down around 367 RMS at 2 ohms, and the 2301 says over 400 RMS at 2 ohms. I'm running 1 10" Lanzar Vibe MaxP104D dual 4 ohm sub. I see good reviews on the 4250D but can't really find any reviews on the 2301. My cousin just picked up a G35 coupe and i am pretty sure his car has the 2301 but i need to confirm that still. Anyway, chime in or vote, help me out here. thanks
    09-10-2003
    Charlotte, NC
    4,463
    Specs on the 4250D
    mono output
    125 watts x 1 at 4 ohms
    250 watts x 1 at 2 ohms
    requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
    PWM MOSFET switching power supply
    Intelligent Surface Mount Technology for cleaner sound
    Thunder EQ bass boost (0-18 dB at 40 Hz)
    variable 40-200 Hz low-pass crossover, 24 dB/octave (since the amp is strictly for low-frequency reproduction, the crossover is always active)
    rubber Iso-Feet allow you to mount amplifier without the mounting screws contacting the amp's chassis
    speaker-level inputs with SmartEngage (turns the amp on when it detects signal from the receiver, eliminating the need for a separate turn-on lead from your receiver)
    EBC2 port for remote control of multiple Thunder EQ-equipped MTX amps
    9-5/8"W x 2-1/4"H x 9-13/16"D
    1-year warranty
    Specs on the TA2301
    Thunder TA Series Class D Monoblock Car Amplifier
    RMS Power Rating:
    4 ohms: 150 watts x 1 chan.
    2 ohms: 300 watts x 1 chan.
    Max power output: 300 watts x 1 chan.
    MOSFET power supply
    Wired remote bass level control included
    Thermal and short LED indicators
    Tuned Bass EQ (0-12 dB bass boost at 40 Hz)
    Adaptive Class D Technology: With MTX innovative approach, the amplifier’s switching energy is constantly changing and is moved away from FM radio frequency ranges as the amplifier’s load and output increases.
    Thermal and short protection
    StreetWires Connectors
    Xtant Technologies Cooling (XTC) thermal-regulated, turbo-charged intercooler
    Variable low-pass filter (at 80 or 120 Hz, 24 dB/octave)
    CEA-2006 compliant amplifier
    Dimensions: 12-11/16"L x 9-5/8"W x 2-1/2"H
    4 or 8-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
    Authorized Internet Dealer
    1-year Manufacturer’s warranty
    05-14-2010
    Coachella, CA
    5,954
    That sub is supposed to be 600 watts rms, so maybe something a bit stronger, at least 500 wrms.
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Good rated brand amps below 150 that do the power your asking for
    MB Quart ONX1 the onx series is known to do or succeed rated power.
    Hifionics BRZ are known to do rated
    Audiopipe
    infinity
    These are just some there are many more
    -Dirty South-
    They See Me Rollin They Hating -Riding Dirty-
    It dont smell or anything so F it.
