Thread: O2 Sensors
Showing results 1 to 6 of 6
    O2 Sensors
    Hi fellas, quick question on 2 02 sensors. I got the codes of the odb and want to replace them. However, I did not know which sensor to buy based on upstream or downstream.
    P0141(Bank 1, Sensor 2)- upstream or downstream?
    P0155(Bank 2, Sensor 1)- upstream or downstream?
    Cool, so from that list, both say (heater). This means downstream right?
    Yes, the heated O2 is downstream
    4cly b1s2 is the p/s downstream. B2s1 is driver side upstream
    V6 b1s2 is the rear exhaust manifold down stream. B2s1 is the front exhaust manifold upstream
    OBD reader says all o2 sensors bad
    deleted
