Thread: How to Install Aftermarket Radio in 8G with Trim
Page 2 of 2 FirstFirst 12
Showing results 21 to 24 of 24
    02-08-2012
    Hackensack NJ
    1,146
    Quote Originally Posted by G-code88 View Post
    Mine fit rite in and it came out pretty good IMO. I didnt really have to do all that but this is def a good write up. I applaud you taking your time out to do this. Me im to lazy lmao!
    These are current pics but it has been the same ever since about 2yrs ago. Sorry Iphone takes crappy pics
    I know it's off topic lol, but where did you get that shift knob?
    It's a simple ebay LED strip and its wired with a pin switch so it turns on/off with glovebox.
    02-08-2012
    Hackensack NJ
    1,146
    Oh ok so it's like the door switches and it closes and pushes the pin to shut off. So how'd you hook it up to power? I'm assuming behind the radio to the fuse box on the driver side. That's how I hooked up my LED glow lights
    I never tap fuses. I simply opened/stripped the radio memory wire and tapped into it.
