Thread: Proper way to remove spoiler?
Showing results 1 to 5 of 5
    I got a sweet trunk from the yard off an S model with what looks to be a stock spoiler attached, just needs a lil paint.
    I went to take it off, removed the three screws and it came loose, but when I tried to actually remove it from the trunk there were what look to be bolts on the left and right edges of the spoiler holding it in place, I looked under the trunk and couldnt find any holes to stick a wrench or something in, any ideas?
    I was considering just using a bolt cutter and cutting the bolts on either side and just using the three screws that I have access too to secure it on but id like to avoid cutting anything if possible ...
    Boost, its whats for dinner
    i think they are just clips but im not sure. try pulling on it.
    12-18-2008
    Central Kentucky
    805
    Quote Originally Posted by dknight3 View Post
    Yeah they are kinda like little clips. They are not really necessary so it wont really matter if you end up breaking one but I would try not to anyway.
    I remember my 3G had clips like on door panels and (4) 10mm bolts.
    ok cool thanks guys, ill pull and prime it tomorrow :)
