Thread: problems with clutch master.
Showing results 1 to 6 of 6
    OK so my c/m is no good fully bless and no pedal pressure still. So went to autozone to gets new one and its not the same as current model v6 looks closer but wouldn't they be the same.
    02-17-2011
    i live in sunny florida
    1,240
    you sure your slave or master is not any good? i check them first if anything
    Brand new slave I bought the granny from Boston hatchet on 3g he said the slave was leaking internally so replaced that new. New ss clutch line no leaks anywhere system was pumped full the same way I always bleed brakes on my dirtbike but pedal can't build pressure.
    02-17-2011
    1,240
    Then its your master...
    Sent from my PC36100 using Tapatalk
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    Yeah but the problem is autozone has 1 model for the 4 cylinder a different on for the 6 are they the same they show a different one on the photo but it looks correct but its special order. They have the one for the 4 has one stub and one oversized hole for a bolt the master I haveia studded for both holes
    08-13-2008
    Waterbury, CT
    3,331
    Did the master just go? All of a sudden no pedal or is this first install or something of that nature. When I replaced my master it took 3 times of pumping it up by hand before the pedal came back on it's own and then more bleeding before it was good.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
