Thread: beginners guide to modding the 2.4L...
Showing results 1 to 20 of 24
    originally posted on club4g and thanks to jhun35... this information should help those who are new to performance modding
    What mods to go for first:
    Building Horsepower in our engine:
    1. One of the very first things you can do to our cars, literally takes ten minutes and easily accessed, is a throttle body bypass--> http://club4g.org/board/performance/...-tutorial.html
    What this does: Well on our cars, engine temperature is a big issue. As most people know, the key to horsepower is getting more air to our engines. The hotter the air is that get into the engine, the less dense it is, meaning in reality we get less air. Colder air is denser air, thus resulting in more air getting in. Cold air>Hot Air. Well we have two coolant lines that run into our TB, One in, one out. This heats up the tb to help our cars start better in really cold temperatures. But, this also heats up our air, which is bad. By disconnecting these from the tb, and connecting them directly, you cool the tb down, which in turn cools our air down.
    2. Secondly, I would go with a Cold air intake---> http://club4g.org/board/performance/...ir-intake.html
    What this does: A cold air intake does exactly what it sounds like it does, allows colder and denser air to be absorbed into our engine. These are also high flow, which our stock intake isn't. Install is straight forward, and a great mod for any vehicle. More power, and better for our engine and gas tank (Not to mention better sound! :bigthumb: ). Lets make this known, Cold Air intake > Short Ram Intake. CAI's are going to allow for better performance than a short ram. They allow colder air to enter.
    3. Next you would want to look into a bigger throttle body. (GT TB)--> http://club4g.org/board/4g-eclipse-g...ttle-body.html
    What this does: The TB on our cars is 60mm in diameter. A good mod to add a little bit of power and better throttle response is to upgrade to the TB off of the GT version of this car (which is 65mm) or send our stock one to proflow to bore it out to 67mm. This allows for more air to enter our engine when we are on the throttle. More air is key, and although effects of this upgrade aren't extremely huge, we are looking for the cumulative effect.
    4. I would suggest while you have the TB off, to go ahead and install an Intake manifold Spacer, and TB spacer
    What this does: The intake manifold spacer is placed in between the intake manifold and the head, while the tb spacer is placed between the TB and the intake manifold. This spaces them apart and helps prevent the transfer of heat from the engine to the manifold and from the manifold to the throttle body. This drastically cools down the air entering our engine and helps add horsepower. Once again, not huge, but cumulative. Plus since your going to have the tb off anyways, might as well go ahead and put these on.
    ***Now, when working on the air flow to and from your engine there is a good guideline to go by. When working on getting better airflow to it, start from the very front (aka Cold Air intake), and work your way back, (Throttle body/spacers). When working on the air flow out of your engine, start from the back (exhaust), and work your way forward (headers). Feeding a lot of air into a restrictive exhaust will get you no where!***
    5. So following that tip, next should be an upgraded exhaust system.
    What this does: We have very restrictive exhaust, not very good air flow at all. By adding a new exhaust (preferably cat back for max performance) you can really increase your horsepower, and get a much better sound. More air traveling through the pipe creates more sound and more power. Be careful if going custom because some states have regulations with EPA standards.
    6. Racing Headers would be the next step--> http://club4g.org/board/performance/...r-install.html
    What this does: This also helps increase the flow of exhaust fumes from our engine into the exhaust pipe itself. Our stock headers have two catalytic converters on them and by adding new headers, you remove them completely. This will create a much better sound and much better performance also. RRE makes a great set of headers for our car that are plug and play (PnP).
    7. Heat wrap the headers and exhaust.
    What this does: Since you are going to be putting the exhaust and headers on, I would suggest to go ahead and heat wrap them. Heat wrap helps prevent the transfer of heat to and from the headers/exhaust which in turn is beneficial in our hot engine issue.
    *Now, we have some pretty good mods on our cars. You probably feel a pretty big difference in the cars performance. Well next step would be to maximize our performance with a great tune.*
    8. AEM FIC (Fuel Ignition Controller).-> http://club4g.org/board/electronics/...-c-basics.html
    What this does: This device will allow you to tweak your car's fuel/air ratio to gain max performance. You can also advance or retard timing using this. You can find a lot of useful info on this site as well as tune's (MAPS) that you can download and apply to your car. Of course to get max performance since each car is different, you will still have to tweak it some. People have seen +30-35 HP on our stock engine consistently w/ the FIC.
    *Now that we have a majority of the engine bolt on's and a good tune, we need to get the power we are making to the ground, with the least amount of HP lost possible*
    9. RRE Underdrive pulley---> http://club4g.org/board/performance/...nstall-gs.html & http://club4g.org/board/4g-eclipse-g...isual-how.html
    What this does: This is a pulley that just replaces our stock crank pulley. It is smaller than the stock one and made from aluminum, which also weighs less (.58lbs, compared to stock that weighs 3.9lbs). This results in the engine moving slower, causing less stress on the engine. This not only helps get more power to the wheels because of less mass being moved, it also increases base horsepower, wheel horsepower, and torque a bit, and is less weight to move around on our already heavy cars. This will also help our engine rev quicker, letting us get to the speed we want at a faster pace.
    10. Front strut and lower tie (front) bars
    What this does: These basically brace the chassis preventing flex and unwanted twisting. This allows you to get better power to the wheels and an all around better performance from your suspension. This will help with traction and handling all together.
    11. Motor Mounts and Engine torque dampers - http://club4g.org/board/4g-eclipse-g...or-mounts.html see post #29
    What this does: These help brace your engine, holding it in place, resulting in less movement when it's building power. The more your engine moves the more power lost in the process. This will help maximize the amount of power you get to the wheels and will also result in smoother shifting.
    12. Lowering Springs or coil overs would be a good addition.---> http://club4g.org/board/suspension/8...g-install.html
    What this does: Lowering springs do what they sound like they would do, lower the car, as do coil overs. Coil overs however usually give you the option to adjust your height and center of gravity for max performance. These help not only make the car looks a million times better, but also improve traction and handling. Coil overs (although MUCH more expensive) are your best bet, and if you can afford them, that would be my suggestion.
    *The next few mods are for Manual Eclipse's only*
    13. Upgraded clutch kit is a must for any manual
    What this does: By replacing your clutch, it allows for a better and smoother engagement when shifting gears, thus resulting in less friction and less horsepower lost from the crank to the wheels. Also when modding up to a certain horsepower, you will need a better clutch to handle the pressure.
    14. After a clutch kit look into a better Flywheel
    What this does: An aluminum flywheel is lighter and allows less friction to be applied when shifting. This results in less inertia and a faster rev. It is also lighter than stock so that helps a lot. This results in less power lost from the crank to the wheels.
    15. Another great addition for a manual is a Short Shifter---> http://club4g.org/board/performance/...all-gs-gt.html
    What this does: By applying a a shorter shifter, it reduces the height of your shifter, and throw by up to 37%. This results in faster and more precise shifts. Combine this with the shifter base bushings from RRE and you have a great mod.
    *End of Manual Specific Mods*
    16. Something else that helps increase whp that most people don't know are Lighter wheels
    What this does: A lighter set of wheels results in less mass that has to be turned when moving the car. Each wheel carries a load of up to almost 8 times it's normal weight!! So when you see a set of wheels and think (Aww those are only 5 pounds lighter they wouldn't make that much of a difference) think again. Thanks again inertia and kinetic friction!!
    *Now, another big step would be to help lower the weight of this beast. A good example would be that for every 10 pounds you drop, it would give the same effect as if you added 1hp to the engine (Note** this does not mean that every time you drop ten pounds you gain a hp, this means that is has the same effect**) These are pretty self explanatory so I will not go into much detail*
    17. Carbon fiber hood, body kit and hatch- Carbon fiber is much lighter than metal or fiber glass
    18. Remove manifold cover
    19. Remove jack, tools and spare tire
    20. Remove rear and passenger seats
    21. Remove radio and speakers
    22. Replace steering wheel and seats with racing seat/sw
    **A few other mods that will help all around**
    23. Oil Catch Can--> http://club4g.org/board/4g-eclipse-g...catch-can.html
    What this does: If you drive your car around for a few thousand miles and take off your throttle body you'll notice it will accumulate a good amount of oil and sludge on the butterfly valve. The can helps prevent oil from splashing into our intake manifold, which helps keep the engine cleaner and less friction and resistance to our air flow.
    24. High Pressure Radiator Cap
    What this does: This increases the pressure inside the radiator, thus increasing the boiling point of our coolant and provides better cooling for our engine.
    25. Rear and front sway bars--> http://club4g.org/board/suspension/8...r-install.html
    What this does: These help stiffen the suspension. This helps prevent body roll and increase grip when handling in corners. This doesn't necessarily add more horsepower, but it isn't always about going fast in a straight line. This is a great addition to any eclipse.
    26. Big Brake kit/Brembos
    What this does: This helps improve performance and braking drastically. Brakes will heat up less and be much more responsive. This is a hefty investment but more than worth the money. People know you're legit if you rollin' with Brembo's :bigthumb:
    27. Energy Suspension Bushings
    What this does: These bushings help remove unwanted flex in our suspension arms. This will help handling and traction a bunch. Our stock bushing have quite a bit of play in them so this is definitely a great addition.
    28. Port and polish
    What this does: This basically increases the diameter of your manifold, headers etc, and smooths them out to increase air flow and reduce air resistance. This will make a drastic improvement in power for your engine but is not the easiest task. I would suggest having a professional shop do this for you.
    This should be a great guide for beginners to follow up to a certain step. Some of these mods are harder than others so beware and do a lot of research before attempting. If you can complete this guide and still want more power there are plenty of more routes to go. Boost, forced induction, increased compression, limited slip differential, new pistons, new cam, the list is endless. It is all about how much money you want to spend, how much time you have, and how much knowledge you can obtain. I hope this helps out anyone and everyone, and that new members can use this as a guide to help them in their builds. At the bottom of this I will add a couple beneficial threads and also my thread that lists all available parts and locations for the GS. Thanks everyone and anyone who helps contribute to this thread also! LET THE MODDING BEGIN!!!
    https://www.thegalantcenter.org/showthread.php?t=49852
    http://club4g.org/board/eclipse-perf...e-modding.html
    http://club4g.org/board/eclipse-perf...g-eclipse.html
    http://club4g.org/board/eclipse-perf...-part-1-a.html
    http://club4g.org/board/eclipse-perf...s-threads.html
    11-18-2009
    Buffalo, NY
    1,758
    Subcribed!! Thank you sir!
    - Chris -
    DRL Delete
    you're welcome, hope the thread helps
    Nice this helps me out alot great job
    I really like the overall with the ree pulley. Small gain in torque, noticiable increase in acceleration and best of all increase in mpg.
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Pretty interesting write up thanks. you have been bringing alot of interesting subjects to this forum keep up the good posts
    -Dirty South-
    Quote Originally Posted by Galant Lopez View Post
    thanks
    Quote Originally Posted by Redhaze View Post
    thanks bro
    00 galant
    This is great, I've been looking for a thread like this since I joined TGC. Im probably not gonna do all the mod but hopefully I'll have a few done by summer.
    Very well written. Maybe change title to 9G 2.4L, For noobs ya know...
    i appreciate it
    Rubix
    Thanx for the great info!
    you're welcome... if anyone has anything to add to it, let me know
    Thanks. I was looking for something like this.
    "We Do Not Sow."
    Quote Originally Posted by freakydeaky View Post
    I did the throttle body bypass and i first bought the 5/16 brass fittin like the link showed but it was too skinny for the hose and the clamps wouldnt get it tight and kept sliddin out, so i went bak and got the 3/8 and it fit in there perfectly even when i pulled it wouldnt come out. Unless it was just mine that needs the 3/8?
    Jhun35
    Nice freaky, didn't realize you put this on here. I just joined to gain more info for our engines.
    In response to galant lopez; yes I had the same issue, but some people have reported the 5/16th working for them. I actually am not using a coupler anymore, and just ran one hose from one end of the manifold to another.
    Quote Originally Posted by Jhun35 View Post
    C i was thinkin and still am considerin doin that, i was just short on cash but it feels sketchy thinkin that coupler will come loose on any bump i hit
    Jhun35
    My coupler didn't seal very well and leaked coolant. I didn't have to get a new hose. Just pulled the hose that use to connect to the top of the tb off the manifold, and the lower hose was long enough to reach straight across and connect where the old one was on the manifold.
    Is urs a v6? Because on mine niether of the hose would have reached to the other side
    Jhun35
    mine is the GS. the 4cyl. 4g69 engine. It reached without a problem
    Guess mitsubishi got lazy with this engine then or something
