Thread: Anyone using E85?
Page 2 of 2 FirstFirst 12
Showing results 21 to 29 of 29
    ^idk. I'm doing it, I think for storage ill just throw in a junk pair of injectors. to me if it is a sealed fuel system, which it should be if your running 40 psi for base pressure, and before you store the vehicle fill it up all the why, that should stop you from absorbing any water really imo. as far as the injectors getting dirty, i wonder if they have a fuel stabilzer for e-85
    08-08-2004
    Las Vegas
    2,099
    autozone sells stabilzer for e-85. honestly if i deploy again anytime soon i would just drain the tank and run some regular gas through it.
    that's a good idea
    The only issue I have is the gunk build up issue. I think the only way to avoid that is buy e98 and mix it to e85..
    10-05-2008
    Grand Rapids Michigan
    1,141
    where are you going to find e98 outside of brazil? lol serious question though
    maperformance sells it by the 55 gal drum
    08-08-2004
    Las Vegas
    2,099
    you can just run some regular gas every now and then to dissolve the buildup.
    True, but I don't know if that's a good idea if your running 35psi+ of boost.
