Thread: 07 Galant ES help with fog light installation
Showing results 1 to 7 of 7
    New Member
    03-26-2012
    Columbus, Ohio
    71
    Hey everyone new to here. I have been searching threads cannot find info I need. I have a 2007 Galant ES and I need to figure a few things about foglights (which are not currently installed). Basically the plastic covers where fogs should go do they just pull out? Or do they need cut or pushed in? I would also like suggestions on fog lights that fit. I want exact fits, was looking at the angel eye fogs..... Any and all help would be appreciated. ****Current Mods**** Ralliart Taillights, Blue Interior Dome Lights, 17" chrome aftermarket rims with nitto gt racing tires. Will Post pics soon. Please Respond fast
    05-31-2005
    4,735
    yes. 4 bolts on the bumper and when you have oem fogs, its also fits the same.
    New Member
    03-26-2012
    Columbus, Ohio
    71
    Thanks. Took panel off saw what im dealing with. If I go with something other than OEM can someone please tell how they mounted their aftermarket lamps...
    Halos?? :clicks red box with x:
    OEM fogs far better and more durable, less rice. <----edits post to at least put in 2 cents.
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    I have the exact same car and installed fogs.. if you have problems just PM me
    You have to unscrew those plastic covers from the back then push them in
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    New Member
    03-26-2012
    Columbus, Ohio
    71
    Thanks guys Im going with stock oem. Last Question the fog light switch I cannot find a replacement that will fit it to look somewhat unmodded any suggestions?
    05-31-2005
    4,735
    if you are going with oem, they sell a kit that has the fogs, switch and relay(i think) together. also if your car came with wiring connected to the plastic fogs then just get the switch from the dealer and its plug and play. Junk yard is also another place to look for one.
Tags for this Thread
