Thread: AC
Showing results 1 to 4 of 4
    AC
    In my 2004 GTS, my A/C light is flashing Green. I thought it could be the coolent level, so I bought one of those compressed air/freon cans. Connecting it I find that is seems to be topped off already because it just sprays everywhere instead of entering the tubing...and the pressure gauge is high. Im wondering if there is anything I can do to tell if my AC compressor/condensor is bad without taking it in somewhere. I know HVAC work will definitely be outta my league.
    Rubix
    I had the same problem a while ago........
    Quote Originally Posted by javoigt View Post
    It might be clogged, you will need to flush your AC system. If you don't know how to, take it to a mechanic. It should cost you around $30 to flush your whole AC system. Doing so will also tell you if your condenser is leaking..Good luck!
    Awesome I will try that first! Thank your for the advice.
    Rubix
    Anytime..let me know how it goes!
