Thread: Immobilizer delete
Page 1 of 3 123 LastLast
Showing results 1 to 20 of 41
    Immobilizer delete
    I know the '00 ecu is locked and we can't tune them but can we at least delete the Immobilizer or no??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    They can be tuned provided that the rom is defined properly speak wit Isaurio he can help you out.
    Quote Originally Posted by deeznutz View Post
    Tuning isn't my big concern I just wanna delete the Immobilizer on my dd
    '95 Kawasaki ZX9R
    Curious to know why?
    Too cheap to pay for a chipped key lol
    '95 Kawasaki ZX9R
    Lmao I was thinking that or remote start.
    Lol yeah remote start could be in the future too but u said they could be tuned. Iirc the '00 ecu is locked and nothing could be done to them at all. Unless u guys have recently figured something out.
    '95 Kawasaki ZX9R
    There's a program that unlocks the ecu it's not an issue anymore. Just give Isaurio a shout he can delete it for ya.
    Will contact him. Thanks for the info.
    '95 Kawasaki ZX9R
    No prob
    02-17-2011
    i live in sunny florida
    1,240
    What program you talking about, I have a 2000 and can't get into it, Iirc I need a tackrix 2.0 cable and ecuflash. If there's another way around that I would like to kno cuz I only have a 1.3 cable..
    Sent from my PC36100 using Tapatalk
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    Quote Originally Posted by finald8ta View Post
    You defiantly need ecu flash with the 2.0 cable as far as whitch program unlocks it you'd have to ask Isaurio iirc the 00 are not locked its a matter of pulling the whole rom for some reason it only gets partially pulled
    I have the 1.3 cable. I don't wanna spend the money for the 2.0 cable. Boooo
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    I dont see a problem on getting to the 00 computer. Tactrix and ecuflash should help. What is the error code on ecuflash? Sometimes the flash connector dont have contact with the plug. Giving error code when you pull out the rom.
    spdracr. PM replied.
    Question. What model is it for. Eclipse or Galant PCM. 2000 dont have immb for the galant *I THINK*. Is the same processor chip as the 99.
    EDIT---The 1.3U cable have problems pulling the rom with new version of ECUFLASH. try downloading a old version of the ecuflash.
    SOHC Turbo
    This is almost 4 years ago when I was trying to understand ecuflash.
    The 2000 has an Immobilizer cuz both of my Gs have chipped keys.
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    LOL. bro you are good. You dont have a XML for your rom. Is not a issue with the cable or locked PCM. it just ecuflash can't located the right memory address to put it together so we could understand. You need a xml made for your rom so ecuflash could open the maps.
    You are all good bro. save the rom. Name it and send it to me.
    Isaurio at hotmail dot com.
    click on continue using this rom. go to file and save as. Name the rom and send it to me.
    We find out with the rom if you have one. Also is this the original computer that the car came with?
    SOHC Turbo
    This is an old rom and isn't the stock rom. Is it hard to get tgw Immobilizer deleted?? Cuz I wanna do it for both cars. Pointers would be great unless its too much to teach over the web.
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    You need to change the hex code. You need a xml with the imm location. Some periphery Define Sometimes it works like that sometimes it dont.
    READ this. MATT "SPD_FRK" tells you the easy way of doing it. Like i said sometimes it works.
    http://www.blackheartmotors.net/tech/Tuning.pdf
    also when you change something keep your STOCK non modified rom in a safe place. Just in case you fuck something up. You could reflash the stock one.
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    Link dont work. BHM is doing maintenance on their website.
    Here is a pic of the info. hope this info helps you. good luck.
    NOTE: IF ANY ADMIN OR MODERATOR IS READING THIS. Please open a section just for Tuning. subfolder with ECUFLASH, EVOScan and other PCM-ECU and tuning related questions. Thanks
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    link fixed.
    SOHC Turbo
