Thread: Immobilizer delete
Showing results 21 to 40 of 41
    02-17-2011
    i live in sunny florida
    1,240
    ok i just went and found the mother of all ecu flashes, i went and dl 1.28/1.29a and got nothing
    on 1.29a i get
    [00:23:46.437] sending init sequence 1 (0001)
    [00:23:49.718] sending init sequence 1 (0003)
    [00:23:52.984] sending init sequence 1 (FFFF)
    [00:23:55.718] no response to any known code
    link to where i found all the downloads for old version of ecuflash
    http://evoecu.logic.net/mirror/ecuflash/releases/
    My tactrix cable driver isn't working lol gotta find my ecuflash CD and install the driver.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    08-08-2004
    Las Vegas
    2,099
    you can just
    download it online you dont need to find the cd
    Quote Originally Posted by underated View Post
    you can just
    I look inside the evoscan folder and found the driver. I searched Google and couldn't find it. Thanks for the tip.
    '95 Kawasaki ZX9R
    05-25-2006
    New York City
    1,028
    Icon12
    [QUOTE=Isaurio;743613]http://www.blackheartmotors.net/tech/Tuning.pdfQUOTE]
    This is going to be really usefull for me soon. Thanks for the link and anyone looking to boost there ride should save this.
    2000 Galant ES = Daily Driver
    Quote Originally Posted by finald8ta View Post
    on 1.29a i get
    I finally have time to mess with this and I get this same message when I choose 2001-2005 Mitsubishi 3rd gen but my car is a 2000 and when I chose the 1996-2001 Mitsubishi 2nd Gen nothing happens.
    Do I need a template for my car?? I'm determined to do this and any help is appreciated it.
    '95 Kawasaki ZX9R
    Anyone??
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    You need to try with 2.0.
    Make sure the flash adapter has good connection.
    SOHC Turbo
    2.0 tactrix??
    Could it be that I'm doing something wrong??
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    Yes. Cable 2.0.
    Like i said. Maybe you need a old version ecuflash. The new one are having problems with the cable 1.3u.
    Double check connection. Try using the second template. 2g since your rom is a h8 chip.
    SOHC Turbo
    I'm using 1.44 ecuflash
    '95 Kawasaki ZX9R
    '95 Kawasaki ZX9R
    ok so i added the periphery configuration to the base xml file and i opened ecuflash and loaded my rom but still cant edit out the immobilizer
    here is what i get
    i spent hours searching this and got this far but now im stuck
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    Bro. Careful of what you put on the xml and value you change on ECUFLASH
    That is the wrong memory location for your rom
    Remember 99-00 ROM are H8 CPU- "YOUR ROM"
    01-03 are SH CPU
    H8 ROM periphery bits memory location starts at 0x272, 0x282 and so on
    SH ROM periphery bits memory location starts at 0xFAA, 0xFBA and so on
    I will send you new xml with the periphery for H8 ROM
    SOHC Turbo
    So what was I doing wrong exactly?? U lost me half way there lol and again your help is truly appreciated
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    U used the SH memory location on a H8 ROM. Is a no go.
    SOHC Turbo
    It looks like you were trying to use a hex code with a binary programmed computer? Lol idk. So i had an issue with my immobilizer, never got it fix, but i was using an evo 8 ecu...
    06-13-2008
    Bronx, NY
    2,606
    I looked around. And is more hard than changing one bit at one location.
    Found 8 location where bits needs to be disable = 0
    From 0x10272 to 0x10280
    SOHC Turbo
  19. #39
    Figured Mitsubishi won't make it easy for us to do this.
    '95 Kawasaki ZX9R
  20. #40
    06-13-2008
    Bronx, NY
    2,606
    When ever you ready we will give it another world.
    SOHC Turbo
