Thread: Moving the battery tray
Showing results 1 to 10 of 10
    08-11-2002
    Waterbury, CT
    400
    Ok well im waiting for my reducers for the CAI to come in so i can install. But i have a question on the battery tray. When i go to put it in, what should i be looking for when i have to move it over?? I know i will have to remove the last remaining airbox peice that is next to the battery. But Are there like bolts or something i have to loosen to slide it over or what?? Thanks
    i just took my battery tray out and used the stock tie downs to hold it down...
    01-10-2003
    BROOKLYN nYC
    1,570
    My batt tray is in the trunk screwd to the floor...with the tie downs and the battery!
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    well arent you special
    08-11-2002
    Waterbury, CT
    400
    <div class='quotetop'>QUOTE(seth)</div><div class='quotemain'>i just took my battery tray out and used the stock tie downs to hold it down...</div>
    How did the battery stay up..i dont get it
    well under my battery tray theres just metal that the tray sits on, i dunno, take off ur battery tray and u will see
    08-11-2002
    Waterbury, CT
    400
    Ok i'll take a look at it..thanks
    01-10-2003
    BROOKLYN nYC
    1,570
    <div class='quotetop'>QUOTE(seth)</div><div class='quotemain'>well arent you special</div>
    Watch next time u IM me for help with your car....WATCH....
    Lol Ye, uder the battery tray there is anothe metal seat, kinda like on the drivers side where the power steering fluid bottle is theres that metal step under it...so you can stillhold the bat down.
    Rob
    rIp 97 Galant
    starting over.
    90 Talon
    brandon
    Just remove the battery tray altogether and let your battery sit way to the left... it'll stay, mine's been fine for over a year now.
    I only used one of the tie downs and hooked it onto some random hole that's in that general area.
    San Antonio, Tex-Mex
    1,413
    When I moved mine, one of the screws still lined up .. I just secured the tray that way. I can get you some visual when I get back B.
    <-Check it out Maz
    My 7g
