Thread: TB options
Showing results 21 to 40 of 85
    The 6G74 tb is 65mm or 68mm depending on the source. I have one in my trunk that I can check sometime today. I just need to find my digital caliper.
    Edit: It looks like 68mm is the point of entry into the tb, but it tapers down to 65mm at the throttle plate.
    07-12-2007
    SoCal
    4,632
    Yeah thats what I thought.
    Omega, so was that a typo? Did you mean to type 6G74 & not 4G74???
    JDM Zenki Conversion
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Yes my bad lol, its a Diamante TB 6g74 and I used the diamante TB gasket aswell.
    4g64T 5spd
    So a 74 TB is a direct bolt on for our motors??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    Im using the outlander mani. With the 74 tb. No spacer needed. I got the diamante tb gasket.
    SOHC Turbo
    07-12-2007
    SoCal
    4,632
    Winning! LoL!
    With that being said looks like I'm getting the 74 TB for the g
    '95 Kawasaki ZX9R
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Just my 2 cents. When I installed the 74 mani n had the 72tb together my car ran like shit. Not knowing that Dion used the 74 tb gasket almost a year later running with no egr I checked n changed to a 72tb gasket. Same issue car bogs n blah. Only able to fix the problem with getting the IAC pigtail n rewire it to install the 74tb CEL gone n car running fine. Don't know if this is off topic but I hope it helps.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Quote Originally Posted by Corey2kG View Post
    Assuming u have a v6??
    '95 Kawasaki ZX9R
    04-29-2009
    3,600
    Yeah lol. I have 2 v6 TB laying around CHEAP if your interested.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Then your last post is good info but we r talking about yge 6g74 TB on the 4g64 engine.
    Are they the 72 or 74 TBs and how much?
    '95 Kawasaki ZX9R
    04-29-2009
    3,600
    I do hope it helps in case someone my run into that issue. N no wish I had a spare 74tb but 72tb's.
    FreakyDeaky
    2kG 6g72/74 5 speed
    How much?? Cuz I can get them from the upull it for cheap.
    '95 Kawasaki ZX9R
    04-29-2009
    3,600
    How much can you get them for?
    FreakyDeaky
    2kG 6g72/74 5 speed
    Like $35 iirc
    '95 Kawasaki ZX9R
    04-29-2009
    3,600
    Ok $25+shipping. Shouldnt be more then 5 bucks. If so I'll pay the diff. For the one I had on my car. Since I know that one works properly The other one is on my spare engine.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Full TB with everything on it??
    '95 Kawasaki ZX9R
    04-29-2009
    3,600
    YIP! If I can find it I'll throw in the IAC pigtail. IDK if you would need it but you never know/
    FreakyDeaky
    2kG 6g72/74 5 speed
  19. #39
    11-18-2009
    Buffalo, NY
    1,758
    If your going to swap to the 72TB, you don't need the IAC pigtail. Just make sure you use the V6 IAC & not the I4 one.
    - Chris -
    DRL Delete
  20. #40
    02-08-2012
    Hackensack NJ
    1,146
    So what I'm understanding from this is the only thing you need to do the 6g74 tb swap to a 4g64 engine is the outlander intake manifold and the 74 tb gasket? If so, I have a 6g72 tb and was gonna get the 74 but I heard the mod was different and you had to bore out things with a dremel which I didn't want to do...is that true because if it isn't I'm gonna be pissed
