Thread: Heart Transplant : master_visionaties build & ? thread
Page 3 of 3 FirstFirst 123
Showing results 41 to 45 of 45
  1. #41
    what???? NOOOOOOO! I liked the direction you were going with it. I enthusiastically read and learn from the different directions people are going with their builds. This one will be missed and sorry to hear you didn't get any support.
    7g Dirt Racer- 95 Galant- 4g64,5speed swap, external coil, dohc swap, 60mm t.b., b.s., a.c., p.s. delete, battery relocate.
    7g Street- 94 Galant GS- 2.0 4g63t, awd conversion, auto swap, 98 gsx ecu, fmic, maft, bs delete.
    3g 00 eclipse gt 3.0 at
  2. #42
    That sucks you had to give up the G im happy you held on to the engine. Maybe you should look into a storage unit or lot?
  3. #43
    Icon12
    I rewired the CAS out of necessity my works legit I trust it bit if I find a better one (prudence)
    taking valves out easy peezy
    got bored and detailed the mc
    a shrine of sorts
    I think that's a nice spot for a sidemount :)
    custom heat shield rough
    and again
    and finally
    sadly all this work is in my moms shed and I see surface rust starting I'm gonna spray it wit oil out of a spray bottle after I clean it. hope it helps . I just can't give up I know when its done it will be noteworthy so ill continue to slowly thoroughly rebuild the engine and when I get another car I foun a few around town I think I can get based on their conditions give em something a lil nicer than get back on track
    Me I'm a lil of both
  4. #44
    08-13-2008
    Waterbury, CT
    3,331
    The side mount issue is not that the bumper can't fit it its that the 7g has a ton of stuff over there in the way. You can fit a good sized front mount behind the 7gb bumper and I think you will find that way easier and better performance wise. Sorry you had to scrap the car man. I know the feeling. I barely have room. Good luck with it.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  5. #45
    i can always relocate the other stuff :)
