kinda small/narrow (wider than stock but not as wide as you could go comfortably) for an 8G but they will fit w/o rubbing. 225/45r17.
Ok so I found some rims and they are the ADR-42 M-classic. But the thing is I don't know if I should get them because its a 17x7 with 48 et offsets. I also did some searching but I wasn't satisfied with what I found. Now the question is will they look good? And what size of tires should I put? Thanks again
I found some enkei but I'm not sure if it will look good because its 215/60/16
You use the wheels not tires.
