i hooked a snap-on scanner up to my car and watched the systems as i drove, no codes popped up, and everything seemed to look good. the engine rpms and the crank sensor rpms didnt match up perfectly but they were close. not sure if that has anything to do with it but i dont think so considering there was a larger variation in higher rpms and that is when i dont notice any problems. the only thing is when i tried to use the scanner to reset base idle the car stalls out
