Thread: looking for a mits parts number guide
Showing results 1 to 15 of 15
    I am looking for a mits parts number guide. I have the part name but now I need to find the Mits part number so I can go looking for it on line.
    jjj
    Google the number :-) I do it all the time :-)
    Win caps
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    I don't get off work til 9 central but at that time PM me I have caps and can get u the part number .
    Sent from my BlackBerry 9360 using Tapatalk
    BGOOD12.
    I am looking for an inside/outside changeover damper motor. It is the black box located behind the glove box that controls whether outside air is allowed into the cabin or if the inside air recurculates. It has plastic gears in it that over time break. I have already rotated the gears once so I figure it is time for a replacement. I love this site, 3 replies in less than 20 minutes.
    jjj
    08-13-2008
    Waterbury, CT
    3,331
    looked in ASA using your keywords and found nothing. need a picture or better description
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    07-17-2009
    554
    He needs to post his vin first
    07-17-2009
    554
    Try this number Mr460374
    The part I am looking for is the black box in the middle of the picture with the three screw and red and green wire running to it and the metal lever on the right.
    jjj
    08-13-2008
    Waterbury, CT
    3,331
    MB813680 and its $94.70 brand new from the dealer
    2014 Lancer Evo GSR
    ^^ I think he got it right, I believe the name you looking for the "Recirculating motor"
    http://oemmitsubishiparts.com/parts/...LATING%20MOTOR
    Not sure if your 7g is the right model that I selected.
    Quote Originally Posted by bgood12 View Post
    why? you don't need vin for CAPS.
    07-17-2009
    554
    I have updated asa , but I could locate it and make sure its the correct part, and it would be specific as to like if he has the cigarrete smoker version of car with filter or not and perhaps other minor things.
    08-13-2008
    Waterbury, CT
    3,331
    All 7gs have this same exact part. I have ASA, caps is outdated, and just type in the chassis code and go. If anything you would need the vin if there were multiple options but for this part it's just one option for all 1994-1998 galants
    2014 Lancer Evo GSR
    You are correct all 94-98 7g had the exact same recirculate motor. The name "inside/outside changeover damper motor" came from a 96 Mits factory serb=vice manual. I found it for $65 at http://www.parts.com/parts/1997/MITS...agramCallOut=5
    jjj
