Thread: Oil leak!
Showing results 1 to 4 of 4
    Jedi iRevo
    Oil leak!
    hey guys, just the other i was changing out the belts on my G because they were worn and squeaking, then noticed a oil leak thought it was the oil pan then went under and i seamed to be from the base of one of the pulleys i clearly see the gasket/sealant (dont know which one) it is broken in about 4 pieces now my question is what part is that so i can replace it someone told me something about a caster?? the oil is getting to the new belts and it squeaks alot more then before...
    There are a bunch is things that could have gone wrong - oil pan sealant, oil filter housing gasket, oil pump gasket, front main seal, cam seal or even head gasket.
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    If you can post pictures, and if you can't try the cheapest routes, new timing belt replace all cam and crank seals new oil pump and seals etc, and new valve cover gasket and check it again in about 5 k miles. I feel these engines when they do leak its only at highway speeds. Or so
    Sent from my BlackBerry 9360 using Tapatalk
    Jedi iRevo
    alright im going to post up pics!
