Thread: Rewiring Harness for O2 Sensor
Showing results 1 to 9 of 9
    I've been having O2 sensor issues for the last year or so and couldn't figure out what the problem was. It turns out that I don't have a stock exhaust manifold so there is no hole for the bank 1 sensor 1 O2 sensor. I can go to the junk yard and pick one up for $20, however there doesn't seem to be a wire running from my harness to that area. I know this car had the entire engine replaced with a junkyard one, but I didn't know it before I bought the car 3 years ago. Is there any way to splice in an O2 sensor into the wiring harness after I replace the header?
    Edit: It's a 2000 Galant ES 4cyl 4g64.
    I dont see why not. Just make sure your wires match from engine to sensor. The connectors will be at Autoparts store and the wire stripper/crimper. If you never done this before, it is real easy! Just get you some spare connector and wire and have at. It is pretty much straight forward. And Only thing I can think of, is the gauge of wire to use which I dont know. But I do know that some O2 sensor have to be spliced if I recall correctly. Bosch sensors or something.
    If i remember that wire harness would be coming from the area of the T-stat. Probably ties into the wire loom/harness right below the cam sensor around the ECT sensor.
    You may want to check your harness first, to get an idea of what you would have to do to fix it and disconnect the battery while working on the wiring then after you fix the wiring, fix the manifold. Thats what I would do if it were me.
    Here is two photos, the wire loom in the red, is it missing?
    Yes it is missing. All the cars at the pull a part place have the same manifold as me. I'm thinking maybe my O2 sensor is under the cat heat shield?
    02-17-2011
    i live in sunny florida
    1,240
    Your o2 will ne before and after the cat on a 2000
    Can u post some pics of you exhaust mani?
    Sent from my PC36100 using Tapatalk 2
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
    Pics of your engine bay would help us help u too.
    Edit: u posted the same time I asked for the pics lol.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    11-29-2009
    Chadds Ford, PA
    2,768
    It's going to be under the car. You have a fed sec car, look past the oil pan and you should see 2. Yours would run into the tunnel under the carpet by the gas pedal.
    02-17-2011
    1,240
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
