Thread: Tactrix 2.0 help
Page 2 of 2 FirstFirst 12
Showing results 21 to 25 of 25
  1. #21
    05-03-2007
    Socal/Central Coast
    3,803
    when you said you deleted the immobilizer and "that worked", do you mean that you were able to save the file on the computer, or that you flashed that file and the car was able to start?
    And then you tried to flash a stock rom and THEN it wouldn't work? Or did you only get the file to save, and once you tried to flash the car, the car would not start anymore?
  2. #22
    Quote Originally Posted by beam514 View Post
    Isaurio is the man. We used teamviewer and he fixed the permissions on my laptop that wasn't letting me get to disable the Immobilizer. Then we finally worked that kink and when I went to flash it failed and kept on failing. Now car won't start. Tried to flash stock rom and still won't let me. When I read the current rom and compare to ecu image it doesn't match as u can see from the pic.
    So no I never started the car with the Immobilizer disabled. And the rom was never flashed properly.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #23
    About 4 hours of sitting in my car in the 97 degree heat and Isaurio figured it out. We used the wrong option to read so it wasn't flashing it right. Immobilizer still isn't delete but my car runs and I'm ok with that lol
    '95 Kawasaki ZX9R
  4. #24
    06-13-2008
    Bronx, NY
    2,606
    It was a crazy day. I''m checking the rom for more testing.
    SOHC Turbo
  5. #25
    Crazy is an understatement. I was sweating from places I didn't think I could sweat from lmao.
    '95 Kawasaki ZX9R
