Thread: Tactrix 2.0 help
Showing results 1 to 20 of 25
    Tactrix 2.0 help
    so i got the cable and it reads my ecu but i get this message once im done
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    You dont have a xml. ECUFLASH can't point out the table without the right xml for your rom.
    Click on the second option. save it and sent it to me.
    isaurio at hotmail dot com
    SOHC Turbo
    Can u give me the XML for it?? cuz I wanna learn how to use it and do my other car too
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    I dont have the xml until i see and compile the rom. Ones i make a xml i will sent it to you so you could open your rom and view the maps tables.
    SOHC Turbo
    So I would need another XML made for my other car??
    And I emailed the rom image to u.
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    yes. Not every rom have the same memory locations. You need to have the exact production year and model to share the same xml. That dont count if PCM was replaced by Mitsubishi because if was bad.
    SOHC Turbo
    both cars are the exact year and model lol
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    I will have to see both rom to see if they share the same rom ID. If they do you could use one xml for both. I have seem rom that are the same year and model but they have 2 different internal rom id.
    Same year, sub-model and engine type. "as a correction"
    The Galant LS have the same timing maps as the GTZ
    The GTZ and LS have different timing maps than the regular V6 ES.
    same goes for auto and manual rom. Same goes for the 2.4L
    SOHC Turbo
    ok then ill send u the one for the other G once i get it
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    no problem.
    SOHC Turbo
    how soon will u have the XML image for me ??
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    If i'm not busy about a day or so.
    When you send them. Send me all the info of the G
    Year, submodel, engine type, manual or auto
    SOHC Turbo
    i just did, what is involved in making an xml ?? i would like to learn thats why im asking
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    you need to learn xml/HTML programming language
    HEX code and how to DISASSEMBLE ROM IMAGES. Stacks etc.
    SOHC Turbo
    Any pointers where I can start??
    '95 Kawasaki ZX9R
    06-13-2008
    Bronx, NY
    2,606
    Try evom. They have some info there. I believe i saw it while back.
    SOHC Turbo
    06-13-2008
    Bronx, NY
    2,606
    Made the xml for you. i confirm you could use both rom with the same xml. Ecuflash should open the tables.
    Make sure you place file 21900037.xml and H8Base.xml to:
    xp 32bit
    C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\gala nt
    windows 7 64 bit
    C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\gala nt
    ECUFLAHS needs to be close while you move or copy to the right directory.
    Good luck.
    SOHC Turbo
    Dude u r crazy quick. I just saw this. Thanks a bunch.
    '95 Kawasaki ZX9R
    i tried to delete the immobilizer and that worked but then i tried to write the rom back on and it kept on failing now my car wont start.
    i tried flashing back the stock image and it wont work and kept giving me errors, i tried 3 different versions of ecuflash on 2 different laptops and no luck
    here are the screen shots
    pulled the rom on the ecu and compared it to ecu and this is what i get
    tried writing a rom and this is what i get
    either the cable isnt reading and writing properly or my ecu is bad..
    thoughts ??
    '95 Kawasaki ZX9R
    05-03-2007
    Socal/Central Coast
    3,803
    lol good luck. Isaurio went to school for this stuff. I learned how to to convert hex into binary in one of my electrical engineering classes, and I have some programming background, but it still doesn't make sense to me when I open up a ROM in a hex editor :P
    Isaurio is the man
