Thread: car starts then dies after a few minutes
Showing results 1 to 6 of 6
    my 95 galant starts fine when cold then dies after a few minutes. it wont start right away again. i have to wait for it to get cold then it will start. i already changed the distributor cap and rotor and fuel pump. i still dont know what is causing it to stall and die. can anyone please help me. thanks
    Any check engine light? Start by checking your vacuum lines
    no check engine light vacuum hoses are fine.
    Does that year have a mass air flow sensor? If so unplug it while cold then start it up and see if it stays running?
    Sent from the best phone in the world, the iPhone using Tapatalk
    Could it be the starter? Or something else electrical?
    Member
    06-18-2012
    RIVERSIDE CA DAT 951 AREA CODE LOL
    183
    It could b a electrical problem, do u have a aftermarket alarm system? I had a 3rd gen eclipse & I had the same issue I had a aftermarket alarm system n my 3rd gen.
    GWAP STACKIN MAKE'S IT HAPPEN
