Thread: Transmission Pan
Showing results 1 to 5 of 5
    NEWBIE thomas_vick's Avatar
    12-06-2006
    Bolingbrook, Illinois
    36
    Transmission Pan
    Please, does anyone know where to purchase on-line a transmission(trans-axle) pan. I've got a crack in mine and need to replace it. The only place I've found is from Mitsubishi and their price is much to expensive.
    2003 Galant GTZ
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    if u go to a machine shop they should be able to weld it and make it look pritty
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
    have you tried rockauto.com or any local salvage yards? I know of some people having good luck with that site. Good luck with the search!
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    Sorry part number is Md763469 retail says 48.71 check me on donherring.com if you wanna make sure should come up as oil pan a/t case. 5 dollars for the info sir. Goodluck.
    07-17-2009
    554
    Did that part # work
