Thread: Dash removal
Showing results 1 to 10 of 10
    New Member
    03-26-2012
    Columbus, Ohio
    71
    Dash removal
    hey guys got windows tinted just got back from car show (will post pix).
    My question is Im sure there is a guide on here im working and dony have time to root through forums. Can someone post link or tell how thanks in advance. I have 07 Rockford if that helps.
    New Member
    03-26-2012
    Columbus, Ohio
    71
    More specifically just to install aftermarket deck. So just the radio part of the dash.
    TGC Regular bgood12's Avatar
    07-17-2009
    554
    All u need is maybe like a butter knife and a philips head screw driver, but the black or woodgrain part of the dash right around stock radio and ac controls that piece there come off. Slip a butterknife in the seam bwtewwn that part and the rest of the dash and pry one part open then use your hands for rest, once that out you can see the screws to reach the radio. You can also put our hands on the part of the middle console below the radio and above the ac control and pull with two hands one on each side til it pops out.
    New Member
    03-26-2012
    Columbus, Ohio
    71
    If I do put aftermarket deck in does it disable the Rockford stock amp and run everything off the new deck?
    You will need one of those mitsu head unit bypass with stock amp unless u bypass the amp and run your own amp.
    New Member
    03-26-2012
    Columbus, Ohio
    71
    My hope was to have the mitsu amp continue powering all car speakers, and then I would have my own kicker amp would power 2 12s. That possible?
    07-17-2009
    554
    very possible I have all infinity inside with the stock infinity amp powering them ( that stock amp will only work with 2 ohm speakers I.e Harmon kardon, infinty, and one more I forget. Then I have second amp in trunk for sub
    With mine I just had to pop off the plastic from the bottom underneath the A/C controls. then from there their were 4 screws I just had to unscrew and then I took the old deck out and left the old half din in. I then got a adapter for the car and soldered them together with the old wires.
    As for you amp still working. Yes it should. If it is wired correctly (wish it should be) the speakers are not wired to the head unit and they are only wired to the amp. Only RCA cables are attached to the head unit.
    Is it ricey?
    Dash removal
    Yea yea yea I know you did it. :P
    I am here: http://tapatalk.com/map.php?v5sbsz
    Is it ricey?
