Thread: noob with gauge problem
Showing results 1 to 7 of 7
    atherts
    Icon5 noob with gauge problem
    I have a 2000 es with the 2.4 in it. Just bought this 200 es but the fuel gauge and the rpm gauge does not work but the speedo does. Where do I start? Is there a way to test if the gauges are good?
    atherts
    Sorry about that can someone tell me how to move my post to the problem section.
    Odds are the cluster went bad replace it.
    atherts
    replaced the cluster and now my fuel gauge work but not my rpm gauge.
    atherts
    The crank sensor is what runs the rpm gauge right?
    just in case, wiggle the harness plugs in the back of the cluster, you might just have a bad connection there.
    atherts
    I will try that after I replace the intake manifold tonight. Does anyone know what wires run the rpm gauge in that connector?
