Thread: V6 clutch help
Page 2 of 2 FirstFirst 12
Showing results 21 to 35 of 35
    TGC Regular Guzm4n's Avatar
    02-02-2011
    Des Moines, IA
    736
    noobs.....thats a dealer only part, but u can try to fix that one lol
    First time doing this kind of stuff haha.
    Quote Originally Posted by deeznutz View Post
    Well here's a Lil bit of info all you had to do to use the auto shaft was widen all 4 holes on the bracket and that would have given you the play needed to shift it over by the cunts hair that it needs to bolt in properly. Hope the dealer don't rip you a new one.. Should have asked here first before relying on a old ass c3g thread
    Man, wish I did ask here before, going to be heading to the dealer tomorrow.
    go to junkyard and pull the whole axle from a manual.
    not too hard....
    02-02-2011
    Des Moines, IA
    736
    Got another problem, the white piece that goes on the shift lever comes off when I try to shift. How do I fix this?
    That white thing sits on a pin check to see if the pin is still on the arm or if the arm is bent and it's just falling off..
    02-02-2011
    Des Moines, IA
    736
    Then I guess the arm is bent cause it still has the pin but when I set the white piece on there it falls off when I shift it.
    It's supposed to be tight in the grove of the shaft above it
    Like so
    02-02-2011
    Des Moines, IA
    736
    I'm going to try to bend it back.
    04-29-2009
    Holyoke,Massachusettes
    3,600
    So obviously this isnt right then?
    FreakyDeaky
    2kG 6g72/74 5 speed
    ^^^ not at all bend that fucker!!! Problem is these junk yards don't give a fuck when they pull parts they just let them hit the floor...
    04-29-2009
    3,600
    Yup just like the bolt hole for the mount. -_-
    FreakyDeaky
    2kG 6g72/74 5 speed
    02-02-2011
    Des Moines, IA
    736
    Okay so I was finally going to take the Galant home but it doesn't start! It cranks but it won't stay on. Anybody know why this is happening?
    EDIT: I forgot to mention when I try starting it, it makes a weird noise and afterwards it smells funny, like something burnt.
    02-02-2011
    Des Moines, IA
    736
    Update: my uncle and I jump started the car, it turned on. It makes a grinding noise when it's in neutral, when I push the clutch pedal in it stops. Sometimes the car turns on but not all the times. The smell is still there. What could it be?
    clutch could be dragging.
    also did you short out the right pins on the auto harness? double check the wiring.
    also check fluid level.
    02-02-2011
    Des Moines, IA
    736
    I double checked the wiring and it's good, all fluids are good too.
