Thread: Project Bodega Beige
Page 29 of 32 FirstFirst ... 192526272829303132 LastLast
Showing results 561 to 580 of 629
  1. #561
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Man thats twice you had do undo the timing belt!
  2. #562
    As requested by everyone, here's the first start-up video!
    http://s233.photobucket.com/user/spd...hsvjm.mp4.html
    Sent from my LG-H830 using Tapatalk
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #563
    Gotta be a good feeling, glad it all payed off for ya.
  4. #564
    Quote Originally Posted by 8thLS6 View Post
    After wanting to set it on fire few times, yeah it's a good feeling.
    Have some mysterious coolant leak that I need to find. And I need to bleed the power steering as well then add the fenders, headlights, hood and bumper and button up the interior.
    '95 Kawasaki ZX9R
  5. #565
    08-26-2007
    1,148
    congrats and it sounds good, what are you doing for tuning.
  6. #566
    Quote Originally Posted by xd_01 View Post
    Thanks man. I'm gonna get it remote tune with a tuner from Florida. Same guy that was tuning me before.
    I don't have a coolant leak thankfully but I have no power steering. I tried to bleed it and no luck. I'm suspecting bad pump
    I have to look for my spare one, i should have one from my last part out
    '95 Kawasaki ZX9R
  7. #567
    07-02-2011
    South Florida, by the beach
    1,076
    Nice!!!
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  8. #568
    Doing more work.
    Changing up the upper radiator hose.
    Also test fitted ets short route uicp and I need a longer coupler in the middle to make it fit. Also since I'm not able to get the tial flange properly welded on there, I ended up ordering an adapter
    That previous mysterious coolant leak is back and I found out it was my heater core. Yay me!
    So just bypassed the heater core for now.
    Still fighting power steering. Gonna completely flush the system out from the old fluid and replace it with new fluid. Feed hose from reservoir to pump is leaking so ordered push-lock fittings and line to replace the braided line.
    '95 Kawasaki ZX9R
  9. #569
    small update:
    heater core bypassed.
    tuner worked on the car more, found out my front o2 sensor is bad, replaced it and retuned again. idles better and drives better (just drove it down the street) still leans out a bit and sputters.
    upper radiator hose is done just waiting for t-bolt clamps for it.
    Moroso battery box is installed in the trunk, just need to finish the wiring for the battery.
    power steering magically bled itself, just need to replace feed hose and flush the old fluid out since its pink which means there is water in the system or massive condensation.
    UICP will be installed soon with a Tial adapter for now until im able to properly weld the Tial flange on there
    Need to somehow squeeze an intake on the turbo with this fan in the way so i dont suck all the hot air from the fan. Evo fan is SO MUCH better than that stupid universal fan i had on there. i will test it for sure on a hot day driving it. temps at idle is around 200F
    '95 Kawasaki ZX9R
  10. #570
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    Nice update! Good to hear about u getting closer.
    Sent from my SM-N920T using Tapatalk
  11. #571
    Current status of the engine bay. Trimmed the catch can lines to proper length. Ets short route uicp installed, and intake and filter (not too happy about placement of it), mounted oil cooler and made lines for it.
    '95 Kawasaki ZX9R
  12. #572
    Had major issues leaning out. Changed tunes and changed roms and still no luck. Starting poking around and found out my COP harness which failed to lock in the pins, so it barely plugged in and it caused for bad spark which caused the ecu to pull fuel and lean it out.
    Wastegate is stuck open. Need to fix that. Adjust my clutch pedal and button her up and drive it.
    '95 Kawasaki ZX9R
  13. #573
    05-14-2014
    Central Florida
    426
    Awesome. Heading the right road look3 like. Tht spool tho!!! Sooocky!!!
  14. #574
    my final conclusion is that i may have a wiring issue,*
    i swapped another set of Toyota denso coils and it didnt make a difference. i changed back to stock coils and the car great. so now i needed to extend the passenger side coil wire to reach the coil properly.*
    after extending it and taping the wire back together, started the car and it did the same thing. undid the tape and started it and started wiggling wires around to see if i can cause it to do what it did before and nothing happened. taped the harness again and tested it and she ran fine.*
    tested my COP harness for continuity on all pins and they are all fine. so im convinced that my ignition harness has a problem somewhere and i need to pull it all out and remove the tape and inspect it.
    '95 Kawasaki ZX9R
  15. #575
    05-14-2014
    Central Florida
    426
    What size wire are u running? (Electrical guage)
  16. #576
    On my COP harness?? 18ga
    '95 Kawasaki ZX9R
  17. #577
    05-14-2014
    Central Florida
    426
    My thought is they to small? Do they get hot?
  18. #578
    Idk but I know all the people that made COP harness used this and gauge. Stock ignition wires are same gauge except one wire
    '95 Kawasaki ZX9R
  19. #579
    05-14-2014
    Central Florida
    426
    Sorry was busy at work. Ok. I will use a 16 and even a 14 with cooper wires. Not the chrome looking ones. Is ok for factory to use tht but i will upgrade for cop. U already have them out give it a shot. And not codes on ecu?
  20. #580
    Quote Originally Posted by boosting90 View Post
    I would have to remake the entire harness with brand new connectors since I can't just unpin those current ones.
    '95 Kawasaki ZX9R
