Thread: Project Bodega Beige
Page 9 of 32 FirstFirst ... 567891011121319 ... LastLast
Showing results 161 to 180 of 629
  1. #161
    How do you like that manifold? I might run the same one since I'm doing a half radiator Anyway.
    Jigz-TGCIL Sosick Motorsports
  2. #162
    Quote Originally Posted by 8thLS6 View Post
    Nice details under the hood
    Thanks man its still work in progress. More stuff to be done.
    I like it. Clearance from starter is awesome beatd using two spacers with the evo turbo. And I was able to squeeze a 3" downpipe without much hassle.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #163
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    It's a pretty good manifold as spdracr said and it solves the starter clearance issue, I just wish the runners were a little bigger for better flow.
    4g64T 5spd
  4. #164
    Didn't underrated say he ran around 400hp out of it??
    '95 Kawasaki ZX9R
  5. #165
    Brandon has an Evo specific manifold on his car. I don't think he's ever ran this one. I remember he ran a cast dsm, a Megan tubular, and his current Evo tubular.
  6. #166
    This is pic was posted by Brandon before. I saved it a while back. Can't remember what thread it was in.
    '95 Kawasaki ZX9R
  7. #167
    I stand corrected Brandon did have this manifold. I'm contemplating it just making sure it will be efficient enough on my setup for my goals.
  8. #168
    What is your goal??
    '95 Kawasaki ZX9R
  9. #169
    This should be interesting.
    '95 Kawasaki ZX9R
  10. #170
    Looks like fun! Love soldering. As long as you know what's what. Haha
  11. #171
    I hate soldering. I don't even think I know how to solder properly lol got some pointers Jon??
    '95 Kawasaki ZX9R
  12. #172
    Use flux.
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  13. #173
    07-02-2011
    South Florida, by the beach
    1,076
    Put shrink wrap on first, twist wires together neatly, warm the wires up with the tip of the soldering iron, touch the solder wire to the solder iron, apply neatly, don't inhale the fumes, let joint cool, give the wires a little tough to make sure the joint is good, slide the heat shrink over the joint, apply heat to the wrap ( i use a lighter, some use the iron but I don't know how to) and done. Hold the soldering iron like a pen and only the tip of the iron is the sweet spot.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  14. #174
    I'm soldering wires to pins. Not wires to wires.
    '95 Kawasaki ZX9R
  15. #175
  16. #176
    Don't solder to pins, crimp pins on. Don't use flux, use flux cored solder.
    Sent from my DROID RAZR using Tapatalk
  17. #177
    What do u mean crimp pins on??
    '95 Kawasaki ZX9R
  18. #178
    Started with this
    5 hours later I got this
    Now it's almost 6am and I have a long day ahead of me. Time to get some sleep.
    '95 Kawasaki ZX9R
  19. #179
    The harness works. Flashed an evo rom that was given to me by 01galant01 and Marc verified it is a good one for me to use to get me to sort out my issues.
    I have an idle issue. I think my iac is bad. I also have a camshaft sensor code.
    Ordered a new iac. New cam reluctor. And NGK spark plugs so I can run the proper plugs.
    Next on the list is a shorter intercooler to allow me to run my crash bar.
    '95 Kawasaki ZX9R
  20. #180
    are you running an evo ecu? iicr youve gotta use the evo cam reluctor or else youll get a crank/cam correlation code if you stick with the stock sohc reluctor. ive got an extra one when i was gonna boost my sohc.
