Thread: clutch slipping
Page 3 of 3 FirstFirst 123
Showing results 41 to 50 of 50
  1. #41
    Listen man don't tell me I'm not listening, adjusting the rod doesn't change the pedal height at all, only backing out the pedal stop does. You say you tried turning the rod right? Did you ever turn it the other way? If you are on your stomach looking at the master if you can't push the slave you need to turn the rod itself like you are loosening a bolt until you can push the slave then tighten little by little to get the max fluid movement
    U made no sense at all. Maybe its just me but I don't understand what were u trying to say
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #42
    i tried that as well i can spin the rod all day, it does nothing.
  3. #43
    08-13-2008
    Waterbury, CT
    3,331
    the rod in the master has threads on each end, you loosen the lock nut that is on the back of that big thing that connects to the pedal then you turn the rod in or out depending on if you can or cant push in the slave with your thumb.i did it to my car, many 2gs and even 1gs with the z bar with success. PM me and ill give you my number so we can talk easier and address each issue right then and there and hopefully i can help.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  4. #44
    im telling you that the rod is NOT threaded on the inside.
  5. #45
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by dknight3 View Post
    I hope you aren't a betting man. Under that big thing are threads and by threading that it changes the adjustment of the piston in the master. If you can't get enough adjustment it is the big thing as its not allowing any more adjustment if it is threaded all the way in and u can't push the slave. Get a piece from another slave that looks like the picture I'm gonna post in a little and that should help you.
    2014 Lancer Evo GSR
  6. #46
    Yea a picture would help cause i am completely lost now... The only adjustment on mine is the pedal height.
  7. #47
    08-13-2008
    Waterbury, CT
    3,331
    pedal height is not adjusted my the master cylinder that is by the pedal stop on the pedal assembly.
    here is a pic with arrows i found of what you see under the dash
    now here is the big thing at the end of the pedal and how you can adjust it
    now here is how the end of my master is, it is not an oem master either but this thing seems to allow easier adjustment
    2014 Lancer Evo GSR
  8. #48
    08-13-2008
    Waterbury, CT
    3,331
    2014 Lancer Evo GSR
  9. #49
    yea 8g is different
    anyway, i ordered a new master and slave cylinder so ill see if that fixes it, if not looks like ill have to bite the bullet and put a new clutch in.
  10. #50
    08-13-2008
    Waterbury, CT
    3,331
    The master you showed looks almost identical to my first master as it has that big thing and it is adjustable. I didn't say the 8g was exactly the same but those Are the same 2 things to adjust as that's how it works in any hydraulic clutch system
    2014 Lancer Evo GSR
