Thread: suspension Q on asian 8G galants
Showing results 1 to 3 of 3
    hi guys,
    been reading the forums for the last couple of hours and can't seem to find any details to answer my question. i registered so i can ask about it.
    my car is a Philippine model 8G Galant GTA. it has a I4 SOHC 4g63 engine. i want to invest on lowering springs or coilovers. a local shop sells tein coilovers for a galant but it is for the EC5W body.
    will it fit in my 8G even if it is for a wagon? local seller doesn't have anything else for the galant.
    reason i asked is if it won't fit i can buy in the United States without any problem but my Galant has 4 x 114.3 PCD. most galants i see on here have 5 holes so i don't know if it makes any difference on my choice of coilovers.
    i'm also looking on purchasing the camber correction kits on ptuning.
    hope you guys could guide me.
    thanks.
    Maybe a little bit late for answer...
    But the different between JDM galants and US galant is that the US galant has McPhearson systems, JDM Galant has Wishbone...
    I'm not 100% sure, but coilovers for Legnum should be fitting your station wagon.
    Good luck!
    Best regards / Martie
    ^ you are correct sir. EA1A, EC5A, EC5W and other similar chassis are compatible
