Thread: Carpet removal scuff plates
Showing results 1 to 4 of 4
    Mystery
    Seems like a simple question but scuff plates doesn't seem to want to come off. I pulled at it but decide to stop and ask... Are they held on by clips or glued? I don't want to break them. I have water coming in on the driver side against the firewall. Water is running out from the evaporator drain so it's not clogged. I assume there is a crack. Seems to be coming from the evaporator drain location and running down along the gas pedal bracket soaking into the carpets when the ac is on. I want to remove the carpet until a fix is rendered. Yes I'm new to this.....
    Member NCamiolo's Avatar
    02-27-2010
    Cape Coral/Fort Myers, Florida
    253
    They're clipped in. An interior trim removal kit would work great, but if you are like me you won't have that. I just used a flat head and some gentle pulling. It should pop out fairly easy if you apply leverage close to the clips.
    those things are very hard to get out. just pull though.
    Mystery
    Thank you! I'm taking it out today
